ok, Im having problems with my brand new wipers. For some reason its skipping in low speed (during rain) and in high speed its skipping less. What could be the problem? I installed everything right not loose or tight. Where can I get a good set of wiper blades that doesn't do this thing?
piece of **** wipers !
I solved this problem by stopping using Bosch wiper blades. I got some TRICO oem replacements from Pep-Boys and they are much better than the Bosch micro-edge blades I've been using in the past. It even comes with a little wipe that you use before putting the blades on to clean them and recondition the rubber a little so it isn't as dry.Not the sports pageNot a magazine
i have toyota wiper blades.
work great!mods: engine: fm stroker lightened and knifedged crank, 11:1, custom crank scraper, fully p&p head and intake mani, bored throttle body, flowed and matched stock injectors, rx7 vaf, apexi safc, gude race cams, modded ecu 8200 fuel cutoff, blaster coil, clutchmasters stage 3 clutch, fidanza fly wheel and timeing gears, msp diff, custom shortram in a cold air box
I use bosch wiper blades and have no problems at all.c+p>c<c+d1>c+p<m+d2>m<m+f>f<c+p>m<m+f>f<f+s1>c+p<c +s2>c<c+p>
