I'm looking to replace my wheels yet again on my 323. I was going to start hunting at local wrecking yards to see if there are any manufactures out there that have a 4x100 lug pattern on a black plane jane 15 to 16inch wheel. Does anyone know of a vehicle that might have this?
Wheels
Originally posted by jewtewned View PostI'm looking to replace my wheels yet again on my 323. I was going to start hunting at local wrecking yards to see if there are any manufactures out there that have a 4x100 lug pattern on a black plane jane 15 to 16inch wheel. Does anyone know of a vehicle that might have this?
Wheels America has been remanufacturing wheels since 1994. With over 35,000 wheels in inventory, we stock the most diverse inventory of original wheels in the United States. Our goal is to ensure our customer gets the correct wheel along with the best customer service experience.
meng
All i know is my aftermarket 17's just amplify any problems my car has ( For example. Bad CV joints,Warped Brake rotors, Bad struts and Old wheel bearings) I am on the search for 16 in miata wheels I like the look of the larger wheels compared to the Protege lx wheels or MX-3 wheels but the protege LX wheels and MX-3 wheels give a smoother ride.
These are the ones i want.
Originally posted by SgtRauksauff View Postyou will need some SERIOUS fender flaring to make those fit under a protege/323/escort. I've got 15x7's, with 42mm offset, and I had to flare them. with 20 offset, that's another 3/4" you've got to have room for....
--sarge2005 Mazda 3
Originally posted by Silentbob343 View PostSo I guess that means 15x7 38mm wouldn't fit very well either if you had trouble with 42mm?
Also, the wheels in my avatar are dealer option wheels for the Suzuki Aerio, 15x6" +45mm offset and 14.2lbs each. Besides white you can find them in a dark gray/gunmetal color and sort of dull chrome color. They are hubcentric to our cars as well with the same 54.1 center bore.Last edited by Hadoken; 12-12-2007, 08:54 PM.Not the sports page Not a magazine
It depends quite a bit on your tires, also. I may have been a bit misleading in my previous post, I apologize.
When I first got the SSR's, they had Kuhmo Ecsta Supra 712's on them, 205/50, and everything was just fine. when I put the Hoosier R3S04's on them, I couldn't actually bolt up the rim to the rear hub, since the tire itself pressed on the strut. it required 15mm spacers to get about 5mm clearance between the strut and tire in the rear I then had to roll the rear fenders out even more than they already were. The fronts, however, never had a problem.
Also keep in mind, the Escorts have the retarded flat wheel arch, the Protege has a nice round one that might eliminate the need to roll it.
--sarge
Any 1990-2005 Mazda 4 lug wheel will fit the BG chassis without modification.
I love my Miata 16X6.5s!
