every time I turn my steering wheel to the right or left the turn signal will come on with it ... could it be a bad switch ..... ?
turn signal HELP..
On my car the plastic peace which turns off the turn signal had deformed and every time I turned the signal would come on. I recommend that you take off the plastic covering and see what is happening inside. To fix my protege I simply grind the the plastic a tiny bit and now every thing is back to normal.
