Hey I finally got the 90 running but the speedometer isn't working. I have the cable hooked up to the transaxle but the needle isn't moving. So what else could i do?
Speedometer help
Should be a two piece cable. Sometimes it can look like it's joined in the middle when it isn't. Or for that matter it could have slipped off the back of the speedometer.1990 Protege 4WD
1 3 5
2 4 R
