There are two first gen's in our family, mine and mom's. As they have aged we've sometimes had the same issues with our cars, and other times we've had different issues. My car every winter has made great heat inside the cabin. Two winters ago mom's Protege could just reach luke warm at best after a long time, it is still like this today. So far she's replaced the stat, the rad (due to common top cracking), its gotten new coolant, and the heater core was blasted out but with little results. She doesn't want the dash ripped apart and the $600 out of her pocket to get a new core.
The little fuse box below the driver's dimmer control - on the black diagram box it says '30A heater', does that relate to the heating system? Or just the blower motor or rear defog? Something I'm not getting - I pulled the cover off, saw all the fuses where they should be...but I see no 30A fuse. Says it is there on the diagram box, but the only thing above the fuses is a black thing, which is the breaker, correct? So where is the heater fuse? I'd like to know because I can easily junkyard the fuse.
Her car also has A/C - it died too, it engages when you press the button but doesn't make cold air, I assume the gas leaked out. Is it true that when an A/C system leaks/breaks, it will affect the heating system? Because it was that summer after that the heating issues started. And I really hope the same thing doesn't happen to me, because my A/C two summers ago while cold, was much colder years before.
