If any one else plans on up grading their lights to leds make sure to get the ones that are the same size as the regular bulbs. I made the mistake of going for the extra bright ones which are 3 millimeters larger in diameter. Regular incandescent bulbs are 25 mm I got the 28 mm led.
LED word of caucion
But on the bright side the 1157 bulbs fit on my other car and the 1157 and 168 bulbs fit on my trailer, which is still benefit. Why spend tens of dollars on trailer led upgrade when you can just change out the bulb and if I break the light housing on the trailer I can just get another cheap one from walmart.
Originally posted by SgtRauksauff View Postgood points!! Also be aware that if you do a lot of driving in snow, LEDs do not produce as much heat, and so the snow will not melt off of the lens, sometimes completely blocking the light altogether. Already happens a bit with the incandescent bulbs.
--sarge
Originally posted by labeo View PostThanks for info! And what about the brightness of LED lamps and their corner of view for the drivers behind you? Are they visible in the bright sun lights? I'm planning such swap but these problems (brightness, corner) make me worrying...
What he say about my mama??1993 Protege LX-Midnight's shadow SOLD
