hey, has anyone ever heard of this?...i swear onetime i saw either online or in a magazine a gauge pod for the A pillar that had room for 3 gauges, but the bottom one was big enough for a tachometer. all the ones i can find now online hold three 2 1/16 inch gauges. anyone seen what i'm talking about? thanks.
pillar gauge pod
i have a 3 gauge pod on my "A" pillar. i have seen what you are talking about, but i still think that keeping the A pillar gauges the same size looks betterWhen you turn your car on... does it return the favor?
A Protege driver named Brock
So his engine he goosed
With much too much boost,
BTW i had to "cut to fit" to make my gauge pillar work. it is our of a 2000+ protege.When you turn your car on... does it return the favor?
anyone who's ever installed gauges into a pillar pod, what holds them in? i mean, how do you install them into the pod? reason i'm asking is, i'm thinking of rigging up my own, but i need to know what holds the gauges into the pod. thanks in advance.94 Protege DX. Custom Intake. Kartboy Short Shifter. Grant GT Steering wheel. Shift knob and boot. Autometer tachometer and air/fuel ratio gauge. Eibach Pro-Kit and Tokico ZX2 Struts. Fog lights. Assorted neon lights. Rebuilt motor.
should be a bracket that comes with the gauge91 323 GTX @ 16psi, 5 speed || December 07 R.O.T.M.
More Information
friction is holding my gauges in. it workes great.When you turn your car on... does it return the favor?
is that a ricer tach i see on your dash in your sig Brock?91 323 GTX @ 16psi, 5 speed || December 07 R.O.T.M.
More Information
Originally posted by redfoxis that a ricer tach i see on your dash in your sig Brock?When you turn your car on... does it return the favor?
More Information
that's just a view of his gauges at night, at least i am pretty sure that is what it is. it is a side by side shot, one day and one night. correct me if i am wrong protoss.'91 323 SE
Sony 12" Sub and amp - 17" Motegi MR7's wrapped in 205/40/zr Visa's - Protoss CAI - Magnaflow Exhaust - Indiglo Gauges and Carbon Fiber Bezel - Ractive Shift Knob, Boot, and Pedals - GroundControls
Coming Soon- Kartboy SS, Pakfeifer Front Bumper
<center></center>
<a href="mailto://67mustangjosh@gmail.com">67mustangjosh@gmail dot com</a>
Originally posted by mustangjosh67that's just a view of his gauges at night, at least i am pretty sure that is what it is. it is a side by side shot, one day and one night. correct me if i am wrong protoss.
yeah from left to right my signature goes dayshot a pillar, night shot a pillar, ECE headlights, with USDM headlight under the lic. plate, vj20 turbo with manifold, and finally 323 truck garnish.When you turn your car on... does it return the favor?
oh ok i see it now.....91 323 GTX @ 16psi, 5 speed || December 07 R.O.T.M.
More Information
protoss, which wire on the o2 sensor did you tap into for the air/fuel ratio gauge? also, would you recommend getting one? thanks94 Protege DX. Custom Intake. Kartboy Short Shifter. Grant GT Steering wheel. Shift knob and boot. Autometer tachometer and air/fuel ratio gauge. Eibach Pro-Kit and Tokico ZX2 Struts. Fog lights. Assorted neon lights. Rebuilt motor.
you dont really need an a/f ratio gauge unless you are going to be messing with fuel mods or going turbo IMO.... unless you want to just be a ricer....then by all means lol jk....91 323 GTX @ 16psi, 5 speed || December 07 R.O.T.M.
More Information
