i need ignition map or advance specs on the gt and gtx engines (bp) and BPT) can any one help me out??
i need ignition map or ignition advance specs
Sounds like you are in an emer...
IS there a problem, your tone sounds like if something is very wrong with the vehicle. Does it start at least?
According to Chiltons Import Car Manual 1983-1990
Chapter: Mazda, section 9-6 of the Gasoline Engine Tune-Up Specifications:::
B= before top dead center
1989 Mazda 323 (turbo)
Ignition Timing is 12B for MT and AT
1989 Mazda 323 (NA)
Ignition Timing is 2B for MT and AT
Looks whos talkin, Honda Ricer wannabe with a Frankenstein Protege.
LOL...a lot of plethora? No matter how hard you try, you sound like a geek anyway, so you might as well be watching the Star Wars and Star Trek. BTW, Star Wars rocks, and I'm not afraid to admit it. There's a reason my sig says Rogue Squadron, and it has nothing to do with liking Star Wars.
Dude, if knowing a lot about cars makes me a geek, then I'm the biggest geek in the world. BTW, wannabe is one word, you should know that by now since it's your nickname and all......
ESA aahhh.."what??"
So that you leeeaarrnnn WWWAAANNNBBBEE geek...
The electronic ignition system is designed to eliminate the deterioration of spark quality which occurs in the breaker point ignition system as the breaker points wear. The breaker points, point actuating cam and the condenser have ben eliminated in the solid state distributor. The replacement was with an ignition module and a magnetic pulse-signal generator (pick-up).
The system is known so my buddy can GOOGLE IT is .... ESA (Electronic Spark Advance Ignition System.
TOOL
EDIT UPDATE:
That is why is from 9 to 11 B! HEELLOO!
Originally posted by WTFSo that you leeeaarrnnn WWWAAANNNBBBEE geek...Past: 1994 White Protege DX ~DEAD~
Current: 05' Onyx Black Mazda 6 'S' ~Bone Stock~
Originally posted by TheMANyou MUST keep in mind the 2nd gen is the bastard child of the proteges...
WTF, you are a blabbering idiot, and you have no clue what you're talking about. Leave problem solving to people who know more than a 'google' search can provide.
Points type ignition has not been used on cars since the 70s, and stock ignition timing IS 10 degrees of initial advance. Like I already said, another 18 degrees is added at 5000RPM. WTF, why don't you go and 'google' and tell us all WHY another 18 degrees is added?
The electronic advance on ALL 90-94 BPs, including GTX and GTRs, is also dependent on AFM signals. But you already knew that, didn't you.
Charles, don't listen to him, as I believe I've provided you with the information you need. If you need to set base maps, they'd be a good start. 10 degrees is even pretty conservative with high boost.
