Are the Headlights POSITIVE or NEGATIVE switching???
I am going to order a headlight flashing kit for my car, but I need to know if it is positive or negative switching between high and low beams, anyone know?? Thanks
DaPro
94 Protege DX SOHC 1.8l 5 Speed
(DaPro)
its better to wait and save then to waste money on crap to get you by....
DaPro
All electrical switching in our cars, including hi-lo beam, is carried out on the positive side of the circuit. The negative ground is common to all electrical circuits.
Happy Motoring!
