my check engine light is always on, is that becuase something is wrong or is it just stuck on? How do i turn it off or reset it?
check engine light
Lol, as a dedicated 1st gen owner I keep a wire jumper in my wallet along with a quick refference sheet i made in Excel."Discontent is the first necessity of progress."
any luck? if its stuck on all the time, but not for the first 5 mins after start up...its your cylinder ID sensor aka your distributor! you have to replace the full unit, thank god i had an extra motor laying around.
JACK
thats code 3 for that btw-Jack
I replaced oil filter and put new oil in it and the check engine light went off. Im confused but at least thats settled, oh yah i also put that engine compression restorer in the oil too and surprisingly it helped out.I feel the difference when switching gears, my car used to lag into each gear(like really bad) and now it takes off alot better.1993 Mazda Protege LX 1.8L DOHC Now with 2 mtx bluethunder 12'' legend series subs, soon to be 2 mtx 12'' 7500 series! in 2 weeks! Im also getting a volfenhag amp
Originally posted by 93protegelxI replaced oil filter and put new oil in it and the check engine light went off. Im confused but at least thats settled, oh yah i also put that engine compression restorer in the oil too and surprisingly it helped out.I feel the difference when switching gears, my car used to lag into each gear(like really bad) and now it takes off alot better.**SOLD** 93 EGT with more suspension mods then your average riced out civic's # of decals + useless "bling/style/culture" mods! **SOLD**
mmhmm, im glad you got it fixed though. it could have been a bunged up internal sensor or something, and changin and flushing could have helped.
JACK-Jack
