Got mine a week ago with 186k on it and runs great. Best of all it was FREE !!
Mileage on your 1st generation
Originally posted by Lex View PostI have an auto protege LX as well with 97000 miles. Anyone had an auto last?
My 323 I sold went to 250,000 on the original drivetrain
My escort is at 195,000 with the original tranny and a newer motor.
I bought an LX-E back in November. It ran so well I didn't bother checking mileage. I put on a good TPS this weekend and HOLY CRAP, my car has 305,000 miles. The tie rods are bad but other than that it's very solid. The guy I got it from has owned it since 95 when it only had 25k on it. All original except front bumper and hood, which got backed over in a parking lot.
Kane
holy miles!!!---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Originally posted by 1967cutlass View PostMy auto DX lasted a bit over 200k miles before I sold it, it's supposedly still running these days so I'd say it's safe to say it went to 210+k
^b6???---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Originally posted by MainstreaM View PostI bought an LX-E back in November. It ran so well I didn't bother checking mileage. I put on a good TPS this weekend and HOLY CRAP, my car has 305,000 miles. The tie rods are bad but other than that it's very solid. The guy I got it from has owned it since 95 when it only had 25k on it. All original except front bumper and hood, which got backed over in a parking lot.
Kane91 protege gt. dropzone mx3 springs, mx3 crossmember, ractive front and rear strut braces, rear lower mx3 brace, 4 wheel disc brakes, corksport ss brake and clutch lines,kvr front pads, ractive cai,ram air hood scoop, modified front bumper, shaved ant and rear trunk lock, fubu ant, short shifter, corksport bronzeoil shifter bushings,92 glass sunroof and tail lights, mx3 center console, autometer gauges (volt and oil pressure) cluster needles painted to match, sound system, 17 inch eagle alloy 193 with 205 40 17 rubber. klze is ALIVE BABY!! . http://www.cardomain.com/ride/2394656http://www.toprotege.com/forums/show...hlight=project[url]
Don't liet that sceer ya.....
Originally posted by ivan15 View PostMy protege has 154 thousand miles. It recently started smoking on cold morning during start up and after warm up it works normal . Dose this mean that it is starting to reach the end of its life.
keep a check on the oil level regular, never over fill it, just over the low mark by 1/2 qt to full, and the smoke will clear after start quicker. Especially if it's a daily beater.
Every other oil change use a qt of Lucas oil stabilizer. And it love baby!
The biggies to these cars are the 80,000100k timing belts, water pumps and tentioners replaced.
If I'm wrong on this I'm sure someone will clear this up.
David
KyLast edited by riverrunnernky; 01-15-2008, 02:28 AM.David
sigpic Ky
good advice david. & yes overfilling will cause smoke---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
definitely a score!!! low mileage 323's are VERY hard to come by. make it another beast!!!---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Thanks for the atta boi!
Originally posted by bpt323 View Postgood advice david. & yes overfilling will cause smoke
Just changed my oil today. At Valvoline. -2 degrees and no warm days in sight, I otped to sit in my Pro and let the greasers looker over, all was good even passed emos. test. 198,532. mi.
My tenative goal is to eval the pro LX at 200k and refurb all worn parts to date. Chassis parts, calipers, coil overs and struts. Engine; at the least change the water pump and timing belt. Change the tranny fluid and Pws fluids, as well as brake lines and such.
Man, if something happend to my Pro LX, I'd have to find another one.David
sigpic Ky
