ok i hooked up my timing light just to check the timing. and i could not find the timing marks. wtf do i have to take off the plastic cover for the timing belt? the manual is very vauge it only explains the sohc and not the dohc....
timing mark?
Originally posted by protouserok i hooked up my timing light just to check the timing. and i could not find the timing marks. wtf do i have to take off the plastic cover for the timing belt? the manual is very vauge it only explains the sohc and not the dohc....
I bet you still have your a/c and powersteering in don't ya?
That makes it a lil harder I hear.
The timing marks are on the timing cover, so you want to keep that on.
If you can't see it from the top, maybe you can see them from the bottom, or turn your steering wheel to the right, and take a peek in there.
