I just want to know how you port out something that has tubes and no big chunks of metal. Becides, any exhaust work he does is going to make the car louder and attract the "pigs". Not like his 18" 45lb chrome wheels aren't already doing that...
street racer
you can still enlarge it a lil. when i first got my header in first thing i did was port it (ie clean up the welds on the ports and down at the collector.mods: engine: fm stroker lightened and knifedged crank, 11:1, custom crank scraper, fully p&p head and intake mani, bored throttle body, flowed and matched stock injectors, rx7 vaf, apexi safc, gude race cams, modded ecu 8200 fuel cutoff, blaster coil, clutchmasters stage 3 clutch, fidanza fly wheel and timeing gears, msp diff, custom shortram in a cold air box
Originally posted by DiamondBlue1my protege is an Standard LX. 1.8 DOCH. the mods ive done is a 9 oz nitrious shot in the intake for a split second acceleration, i had an intake cone wit a modifided exhaust. i mod an RX7 short shifter for my factory shifter. future plans is to get another bp-ze engine, have it bored wit a stroker, better cams, port out the exhaust and intake prot on the head, bore out the valves for bigger valves, CIA, 2.25 cat back wit a flowmaster exhaust, and add the 94 tubular exhaust manifold ported out to keep the pigs off my back. and some more stuff i just cant think of right now. what do you guys think.
cutlass thankyou!
ya something does wreakmods: engine: fm stroker lightened and knifedged crank, 11:1, custom crank scraper, fully p&p head and intake mani, bored throttle body, flowed and matched stock injectors, rx7 vaf, apexi safc, gude race cams, modded ecu 8200 fuel cutoff, blaster coil, clutchmasters stage 3 clutch, fidanza fly wheel and timeing gears, msp diff, custom shortram in a cold air box
Originally posted by DiamondBlue1future plans is to get another bp-ze engine, have it bored wit a stroker....Originally posted by 95progecko?
don't you mean GEICO?
Originally posted by celborni wouldnt recomend stroking the BP. you loose ALOT of redline and HP. cause thats how our cars get power. its not like my nova where it had a 5200 redline. if you want to throw power at it destroke it and bump your redline way up. but im not entirely sure that ya can do that on these engines:-X
It all depends on what you want: torque or top end.
Originally posted by turprowell i can say that i condone street racing but i do race to the speed limit. nice kills though. i luv whoopin honduh asses,even if the fastest we go is to the speed limit.Almost there
jdm tails... check
jdm bumper... check
ms lip... check
ms grill... check
ms sideskirts... check
ms rear skirts... check
ms spoiler... check
ms struts... check
Still trying for a bp swap..:
well ummm lose rev's by stroking? not totally tru even on a chevy engine. yes if your rod ratio gets 2 out of whack yes but on our motors stroking and boring them will get you a nice rod ratio i have seen 9k on a flyin miata stroker engine on the street. so i wouldnt say that. in the same ive seen 5grand 383 chevies and 8 grand monsters all depends how you build it.mods: engine: fm stroker lightened and knifedged crank, 11:1, custom crank scraper, fully p&p head and intake mani, bored throttle body, flowed and matched stock injectors, rx7 vaf, apexi safc, gude race cams, modded ecu 8200 fuel cutoff, blaster coil, clutchmasters stage 3 clutch, fidanza fly wheel and timeing gears, msp diff, custom shortram in a cold air box
yeah its all about the rod ratio.Almost there
jdm tails... check
jdm bumper... check
ms lip... check
ms grill... check
ms spoiler... check
ms struts... check
