i need to change the hose that stops and goes into the block between that and the intake, cant get the intake off, got all the obvios bolts off any ideas?
removing my intake 93 protege lx
Originally posted by Thraxsteri need to change the hose that stops and goes into the block between that and the intake, cant get the intake off, got all the obvios bolts off any ideas?
A pic of what you're trying to describe would be helpful, but did you forget to take off the intake manifold support bracket?
theres one under the throttle body...at least on the dx mani, you gotta take it off to get it....Last edited by 92dx; 05-30-2006, 10:15 PM.
whats the second line coming off the throttle cable wheel? the one on the top, i've never seen that before, always wondered why there was a second notch for a cable.
any ideas? im clueless
JACK-Jack
Originally posted by Thraxstersounds reasonable to me, i said **** it, sent it to a shop, after trying to pry the intake off with none of the screws in it, im letting the gearheads work it out, ****ty tho i couldnt do it myself.
I just took this pic for you to show you what you were missing. There are 4 bolts on the bottom.Last edited by Jho; 10-22-2006, 05:43 PM.
