so a new problem has come up, very interesting also. when ever im driving down the road and the road turns right, or when i make a right turn faster then idle speed it sputters and tries to die. it wont do this then the cars stopped or any other time......any ideas?
car dies when turning right????
i know exactly what it probably is but don't remember the thread or instructions on fixing it. But it's your fuel pump/sending unit/lines. There's a funky problem when making turns where it cuts off fuel/has trouble pumping it out. I'm SURE someone will post the instructions. It's common with the escort/pro im told, although ive never had any problems with my sedan.Seth
2010 Mazda3 i Touring
Originally posted by mazdaspeed?i forgot to ask also, is there a difference between fuel pumps in the proteges? my pro was a SE but i did a almost full LX swap.
I do know that the B8 has a fuel injector rate of 180ml/min, and the BP has a fuel injector rate of 250ml/min. So the B8 requires less fuel, and might have a matching fuel pump.
thats different hmmmm i dont have an answer.... i know the link i left solved my problem. but i have a EGT so same as the lx has.mods: engine: fm stroker lightened and knifedged crank, 11:1, custom crank scraper, fully p&p head and intake mani, bored throttle body, flowed and matched stock injectors, rx7 vaf, apexi safc, gude race cams, modded ecu 8200 fuel cutoff, blaster coil, clutchmasters stage 3 clutch, fidanza fly wheel and timeing gears, msp diff, custom shortram in a cold air box
Originally posted by mazdaspeed?heres what my sending unit looks like, i cleaned the filter cuz it was nasty and i didnt have another filter. its doesnt look like the one in the link escortkid left, so im sort of lost on what piece im suppose to be replacing......anyhelp???Last edited by mannydingo; 07-01-2006, 10:37 PM.
