Hey guys I need some info on the roof liner. I search the forums but found nothing. The roof liner in coming off and Its getting bothersome. Anyone had to deal with and could share your info I would be appreciative.
roof liner
Mine is on its way out too, so I've been thinking about alternatives. First I wanted to take it out and leave just the bare metal, but then I realized how hot it would get inside the car. Now I'm thinking some kind of cut-to-fit panel (e.g. plywood) that could be painted or whatever with fiberglass insulation on the back.
Just a half baked idea.1990 Protege 4WD
1 3 5
2 4 R
In what section of a store like target walmart or home depot would I be able to find some spray adhesive. If I cant find the adhesive at a B&M store . I'll just purchase online. I found this one http://www.autobarn.net/headulinad.html I've read good reviews about this product.94 LX
i have redone many headliners. the first step is getting the headliner out of the car with minimal damage. next remove the fabric and use a wire brush to remove the soft foam fabric backing from the hard foam backing. next go to a local fabric shop and ask for headliner material.... you might have to visit several stores to find the right color but you will find it. use spray adhesive on the hard foam backing and on the foam backing of the fabric itself to ensure a good stick (it's not necessary to drench it but it does help to spray both surfaces) i always wrap the edges around about and inch before trimming. last, reinstall the headliner being careful not to snap the hard foam backing.
GOOD LUCK!!Last edited by martiniac; 08-12-2007, 01:47 PM.
Originally posted by TiKi View PostIn what section of a store like target walmart or home depot would I be able to find some spray adhesive. If I cant find the adhesive at a B&M store . I'll just purchase online. I found this one http://www.autobarn.net/headulinad.html I've read good reviews about this product.
Originally posted by TiKi View PostI seem to have severely torn the headliner cardboard or hardfoam or what ever it is . What can I use to reinforce it??
good luck!
If you going to do the headliner, sand of the glue all the way down to the cardboard. Pick the material and the color you want, get some 3m spray on glue
and spray the leveled surfaces evenly and the surface where its curved a little heavy you want to make sure the material sticks and trim off and excess material. If the material doesn't quite match with the interior pieces, you can buy upholstery paint at the upholstery shop.
