Ok so as some of you know a couple weeks ago i was reading 19.xx volts charge on the battery. well i was told voltage regulator, and since that was internal to the alternator i replaced the alternator. i also decided to replace the battery at this time. well after i put in the new alt it still was charging 19.xx volts. well then a few hours later it was completely normal at 13.5 volts. well now its back to 19.xx and changes with the revs anyone have any idea what it could be? remember, brand new alternator.
Electrical problem
if you dont have it figured out head down here in the morning, i need to get the 626 running right and you can play with more BG's than you have ever seen
PM me for an addy"Discontent is the first necessity of progress."
problem is im stuck at my house until i get it running. lol
im going to go test the resistance on the wire from the battery to the connector. see if that tells me anything. if i cant get it worked out im going to see what i can do at school monday. and btw shawn, when i get a bp ready to swap youll head up here right?
Originally posted by Ace View PostOk so as some of you know a couple weeks ago i was reading 19.xx volts charge on the battery. well i was told voltage regulator, and since that was internal to the alternator i replaced the alternator. i also decided to replace the battery at this time. well after i put in the new alt it still was charging 19.xx volts. well then a few hours later it was completely normal at 13.5 volts. well now its back to 19.xx and changes with the revs anyone have any idea what it could be? remember, brand new alternator.
