Does anyone know if pretty much the whole front wheel assembly from a 98 protege (not sure engine size) will work on a 94 protege dx (1.8 sohc) instead of maybe having to press out/in a new wheel bearing?
94 & 98 wheel assembly
hmmm, as far as I know they should interchange. I installed calipers/pads/rotors onto my 97 from my 93 323 part out. Spline count is the same as well-Jack
Originally posted by pirite View Postso by wheel assembly, you mean steering knuckle, wheel bearing, and wheel hub (i guess it could also be called a "loaded knuckle")
Originally posted by Mazda_Powered View Posthmmm, as far as I know they should interchange. I installed calipers/pads/rotors onto my 97 from my 93 323 part out. Spline count is the same as wellLast edited by magnum7269; 03-28-2011, 07:00 PM.
