    Originally posted by CODY004WD View Post
    Just bought GTR rods and Pistons w/ARP rod bolts, and a ceramic coated BP26 exhaust Manifold and T3 adapter for the Hatch! The plan is to build a GTR shortblock, and toss the BP4W head on it. Then for the turbo, I'm not really sure what all clears with the bp26/t3 adapter combo, but whatever the largest turbo I can clear and get a good deal on, will be bolted on. And I want to run the 2000 miata harness and run either Hydra-nemesis, or Megasquirt. Whichever I can find a good deal on. I want to run distributor-less, but probably wont do COP's... And I'll probably get an M-factory diff and Kia trans for the swap too. Sound about right for a DD?!
    The ones that were 4sale on CP?
      Too bad you were not here, there is a yard I may go to tomorrow after work that has 3-5 sephias in it. 1 I know for sure is a manual trans.
      FS Forged H beam rods
      awaiting test fit
      Aluminum CAS/Distributor caps
      BP oil jet eliminators
      EV14 fuel rail spacers
      More stuff coming soon.......
        yo before you buy a Hydra, talk to Ben, I'm pretty sure he has one in his MSM and was having some issues with it.
        92 240SX: KA/T25, nerd mobile
          Originally posted by DuRWooD View Post
          Sounds like a good plan Cody. What are you going to run for an intake manifold?
          I'll build an upper plenum for the lower 4W manifold. Or modify a gtr mani if I can get a good deal on one.
          Yep to all of it.
          I'll see what his deal is. I've seen pretty good results with them, and I figured finding a used local deal should be easy since I'm relatively close to Flyin', but it really depends on what I find...
          I know where several are, I just need to save up some more cash, and get some free time... Gotta put a tranny in my co-workers chevy lumina first...
          Current:
          68 Torino GT Fastback
          86 MR2
          91 F150
          94 Escort Wagon BP swap
          99 Escort Wagon BP swap
          00 Miata LS
          08 Arrow AX8
          14 Mazda5
            I've done it before, just use some sheet metal to shim the bracket.
            good call! If I do end up removing too much bushing, I can just add a spacer from the bottom
            as long as the bracket that holds the bush still "bottoms out" and its tight,should be fine.If im reading you right.
            Sweet, ya we're all on the same track lol
              Changed the oil, rather successfully, today. No spills! lol Also rotated the wheels and swapped in my matching tail light that came in the mail today. Now the car doesn't look goofy from behind.
              Team Fail Motorsports
              That's just the nature of the beach.
                180 miles and the BG seems solid! I can't get over it hasn't leaked a DROP of oil from the turbo since I had the turbine seal scare :/ lol
                  Got some Kia Multi hole injectors from the junkyard for $20.
                  Made an interesting discovery at the junkyard as well today that I think a few people will be happy to hear about, more on that later after I do more measuring though........
                  awaiting test fit
                    Got some nuts instead of the wingnuts for my cutout plate and sealed that up. I've got a new lease on life now that I'm driving a car without exhaust leaks. lol also replaced a couple hose clamps that were stripped
                    -Steve
                    94' Protege < Worklog<SOLD!
                    VF10 powered!
                    262 Whp & 257 Wtq
                    13.1@107
                    '02 Suzuki Bandit 600s
                      talking about the newer kia motor/tranny? jinx and i have been working on buying one to teardown >
                        It does have to do with the BG Sephia but not that part of it.
                        Do you mean the Kia BP or some other Kia engine?
                        awaiting test fit
                          Changed out my fancy OEM dual stage t-stat since it was acting up (turns out the rubber seal for the smaller stage had lodged it open) and installed my dual core rad
                          All seems to be good now, no fluctuating temp gauge AND I have heat!
                          Also swapped in the Supra VAF, but I think the guy I sold it too messed with it so I'm having issues getting it to run properly in boost
                            wiring wiring wiring .. yay me
                            side note . have an rpm activated switch to add .. best starting point for vics with boost ? ideas ?
                              around 4,500-5 I found was best
                                I might install my polished VC tom, I hear that toyota rtv is the stuff to use right? I dont want any leaks lol if i get the time and also need to tighten down a few things around the inside of the car
                                I wish i had heat some times in my car
                                93 Mercury Tracer SW
                                01 Honda S2000 Future Boost
