Jack up under each control arm and feel for play up and down, and side to side. also, take the tire off and see if you notice anything with the brakes
Originally posted by FE3-323 View Postneed another trans? ^
I was in the process of pulling over anyway, so when the trans locked I just slid right where I was pointed.
What's weird is that with the shifter in neutral, I can drive it. I'm pretty sure it's in third. Obviously then, when I put it in any other gear it binds and won't move since its in two gears at once.
i changed the oil on the 323..... also i have tried two different thermostats and when im cruising the temperature drops down to C, when im idling it goes halfway, and i have heat so i dont think thermostats is stuck open. Has anyone had this happen to them before? could it be the temp sensor?
Picked up 8 snow tires for $140. A nice set of winter IPikes, and my old set of studded Altimax Arctics. Sold the altimax tires on egt fan blades two years ago for 300. Dude bent a rim within a few weeks, and they've been in storage since! He listed them on CL, I recognized them, and figured why not!
I have two sets of EGT 7 spokes sitting around, so each set of tires will be mounted and balanced, and I'll have tires for many winters to come! Sell the three good fan blades, and scrap the bent one, I might even break even!Current:
68 Torino GT Fastback
86 MR2
91 F150
94 Escort Wagon BP swap
99 Escort Wagon BP swap
00 Miata LS
08 Arrow AX8
14 Mazda5
Originally posted by miK3Pro View Posti changed the oil on the 323..... also i have tried two different thermostats and when im cruising the temperature drops down to C, when im idling it goes halfway, and i have heat so i dont think thermostats is stuck open. Has anyone had this happen to them before? could it be the temp sensor?
Originally posted by MazdaNoob View Posteither you have a big assed air bubble in there or the water pump is failing
I picked up some replacement bulbs and the H4 harness so I can put in my new head lights. Maybe this week if I can get my diesel heater to start I'll put them in. It's currently 2 degrees outside and the water froze today at the house right at the meter, the high today was 6. Where the F is some warmer weather?Create your own VB Gallery here.
Yep, it even happens to me in Phoenix when it gets in the 40-50's. I put some cardboard in front of the radiator to partially block it, or reduce the airflow going into the front of the car somehow.
I would try blocking half of it and see what happens first. I currently have about 2/3 of min blocked off it works fine like that.92 Mazda MX3 GS> For sale, $1750 OBO
Aluminum CAS/Distributor caps
BP oil jet eliminators
EV14 fuel rail spacers
More stuff coming soon.......
Originally posted by Josh Chaney View PostI did something. Not sure what. Something is either broken or in the process or breaking. The right front was being funny. Going down the highway tonight the wheel would periodically jerk out of my hand. It felt as if the steering had broken and the right front wheel was turned fully to the right. I could barely keep the car on the road, it was pulling so hard to the right. So I pulled off at the next opportunity and it felt like the wheel was about to fall off and was making some really evil noises. I pulled into a space and jiggled the wheels to check for play and the right front seemed to move a bit. I was nearly home, so I figured I would limp it back, but as soon as I pulled out of the space, all was well. Not a sound or movement. The whole rest of the way home I thrashed the car with hard stops, launches and some aggressive slaloming and nothing happened. I'm gonna take a look underneath it tomorrow and see what I find. Any ideas?
Originally posted by redheddude222 View PostI'm pretty sure the trans grenaded in my mx3 today. Front wheels locked up on the interstate and I slid to a stop. Killed some time while waiting on the tow truck and took a few pics.
And a fancy HDR.
Found a pretty bad leak in my original all brass (or maybe copper) radiatior. I couldn't see it before I refilled it. Only had about half the coolant volume in it before due to slow onset. Oops. Anyway, I'm going to pull it today and see about having it re-cored.1990 Protege 4WD
1 3 5
2 4 R
Originally posted by DuRWooD View PostTaking it for a tune?
Tune should be in 2-3 weeks. (And the inevitable blowing of the motor. )
I'm ALMOST hoping the motor blows on the dyno. Will force me to finish the race bomb and put it in.
Originally posted by tehmonkay View PostThey arent fail safe ones are they? Do you have your heater hoses routed properly?
