Pulls one way when accelerating, pulls another way when braking. Steering feels loose. When I go over railroad tracks it makes a ton of racket, like a bad strut mount. Everything in the entire front end is brand new now, except for the rack itself.
Wheel bearings?92 Mazda MX3 GS> For sale, $1750 OBO
Aluminum CAS/Distributor caps
BP oil jet eliminators
EV14 fuel rail spacers
More stuff coming soon.......
Originally posted by redheddude222 View PostPulls one way when accelerating, pulls another way when braking. Steering feels loose. When I go over railroad tracks it makes a ton of racket, like a bad strut mount. Everything in the entire front end is brand new now, except for the rack itself.Ian Boyd- Bellingham, WA (click vehicle to view)
1988 BF GTX
1990 x2 BG AWD Protege
1991 Escort GT- SOLD
2005 Corolla
New energy suspension control arm bushings (double and triple checked the tightness), new struts and mounts, new inner and outer tie rods, new ball joints, and wheel bearings are tight and don't make any noise. The only option left is the rack itself. Alignment wouldn't cause a rattle over bumps.
What type of springs you running? Coilover sleeves?
Is it a noise or can you feel it too?Ian Boyd- Bellingham, WA (click vehicle to view)
1988 BF GTX
2005 Corolla
I would also say check the brake calipers, but that wouldnt cause the steering to feel loose.
How are the rack bushings? That could cause all those symptoms.92 Mazda MX3 GS> For sale, $1750 OBO
You should pull the rack and strip it down to see if you can find the issue, then re-seal it back up for manual steering? Just a suggestion if you're not wanting to source another rack.-Jack
is the tension on the rack shim adjusted properly??? when i converted mine to full manual. i noticed it definitely had to be tightened more.
Refer to my mx3 manual rack thread- its super easy anyhow---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
