What coils did you get ?
trimmed up my sleeve pieces for my own coilovers getting them lathed true tomorrow then off to be welded!!!---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Originally posted by bogaut View PostWhat coils did you get ?
*update* I emailed them again and told them to just send me Yellows for a 323. I'll deal with the higher front spring rates.Last edited by ThatGreenBG; 06-16-2013, 11:41 PM.Team Fail Motorsports
That's just the nature of the beach.
I was up visiting my folks with my friend Adam this weekend, sold some rear spindles, did a boost leak test to find my lower injector spacers/seals aren't sealing on a few of the injectors (had the inlet pipe capped off with my tire valve, then capped off the exhaust pipe...worked VERY well) also found a few boost leaks that we fixed up...damn thing whistles/hisses/leaks past 3psi still though
...so gonna have some fmic pipes bent up for me next month...gotta get this thing reliable for the winter!!!-Jack
Trying to install a relocated hazard switch near my A/C switch. Tired of the ford ones in the top of the column that always break.92 Mazda MX3 GS> For sale, $1750 OBO
Aluminum CAS/Distributor caps
BP oil jet eliminators
EV14 fuel rail spacers
More stuff coming soon.......
Please enlighten on the spring rates for both!!!
thanks!
Originally posted by Josh Chaney View PostI was going to get Yellow Speed coils. I did some research on them and people from M3s to Integras rated them above stuff like BCs, with use in auto-x and track days. They're all the rage for the BJ chassis right now on other forums. Plus, they were lower on the price totem, so I ordered ones "for an MX3" because I liked the spring rates better. However, they said that they only had one set left which was damaged and missing some stuff, so I got an upgrade to D2 RS free of charge.
*update* I emailed them again and told them to just send me Yellows for a 323. I'll deal with the higher front spring rates.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Done a boost leak test and found a few leaks, also I'm having slow spooling problems so I checked the actuator and it was slightly open :/ A little bit of fiddling and it closed so I greased the hell out of it! Will test drive tomorrow
Anyone had an issue with the actuator like this befor on a VJ20?1989 BP Motor, 9.8:1 OEM Pistons, BP22 Intake Cam, VJ20, GTX Intake Mani, FMIC, Alloy Radiator, HKS SSQV I, K&N oil and air filters, Innovate LC-1, 10W50 Mobil
only when I had it installed at the swing arm backwards (pushed up through, vs pushed down)
I did a boost leak test as well (cap/valve on turbo inlet and cap'd the tail pipe) and turns out everything leaks! lol injector lower spacer/seals, some of the IC piping I worked on...blah!!! Got most of the piping solid but god this noise it makes is driving me insane!!! It's been doing it for a while now too...I barely get past -10vac (I don't go into boost, or beat on it like this) and you can hear the damn thing fartin/leaking up a storm.-Jack
Picked up a set of 2000 ES 4 lug 5 spoke wheels from a local guy for $30, not a bad price. Need to get some rubber now.Create your own VB Gallery here.
you do realize those rates are high for our cars (fronts at least)
5 or 6K would be my max. personally i can't really see too much practical use otherwise.
Originally posted by Josh Chaney View PostMX-3 are 7k/4k
323 are 8k/4k---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
7 & 8k aren't as bad as you think Ryan lol. I've had both on my car and it was fine for daily, would have been MUCH better if I had adjustable dampening though. Then they'd be bad ass. Currently running #350s on ZX2 spec struts with no complaints at all though.-Jack
