extra valve cover huh? *cough powder coat cough*
94 Protege DX 5sp
for discounted prices on blasting and powder coating check out. (mention club protege to receive a discount)
https://www.facebook.com/AS.Perfomance.Coatings
After two years of being broken I fixed the cruise control.
If I ever get to the A/C everything in the car will actually work.Beater=/= Sleeper
Originally posted by Kitty View PostAfter two years of being broken I fixed the cruise control.
If I ever get to the A/C everything in the car will actually work.My car is a Vazondissan. Part Nissan. Part Mazda. Part Ford. Part VW. Part Honda.
pulled my drivers side seat out....... time to modify the seat rails a bit---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Got my front end all converted over to GT-R stuffs, but found my calipers are sticking a bit. Can anyone tell me the piston diameter, so I can order new ones tomorrow? I may have to just touch up the pistons I have, and put new seals in.sigpic
1992 Familia GT-X
1988 323 GTX
2011 F150 Lariat Ecoboost
2014 Civic Touring
94 Protege DX 5sp
I failed to obtain a rebuild kit for my GT-R calipers, so I decided to give something else a try. Picked up some Mazda Millenia S dual piston units. Low and behold, they pretty much bolted right up. Just had to shim the bracket in 1mm so it would sit perfectly center, and trim the dust shields.
That was just mocking it up, as I wasn't sure they would fit. Now I'm going to clean off the packing grease and paint them black.sigpic
1992 Familia GT-X
1988 323 GTX
2014 Civic Touring
Thanks. I'm doubtful they would fit your setup unless you found some rotors with a very small offset. There's 10 mm difference in clearance between the rotor center of this setup vs a Probe/MX6 etc. This is using 626/speed Protege rotors, which I believe have the same offset as the older stuff. Basically, the GT-R and the millenia have a further distance from the hub face to the caliper mounting ears than the other setups. It's close enough that I'm sure you could make it work.sigpic
1992 Familia GT-X
1988 323 GTX
2014 Civic Touring
broke my PS/ac belt.....only to find out the other guy welded the belt tensioner to the mount...
This guy must have just welded everything that broke instead of buying a new bolts94 Protege DX 5sp
Originally posted by Wtfracing View Postbroke my PS/ac belt.....only to find out the other guy welded the belt tensioner to the mount...
I ll throw a tensioner in your box. Sorry I havent gotten a quote yet.alll the stuff is boxed up in. my back seat.Ian Boyd- Bellingham, WA (click vehicle to view)
1988 BF GTX
1990 x2 BG AWD Protege
1991 Escort GT- SOLD
2005 Corolla
continued the tradition of **** going wrong whenever I try to modify it. Iceman is on, but I'm going to need a more permanent solution for that vacuum line that goes from the intake pipe to the booster check valve.
also, now that I'm back from vacation I can spend more time cleaning up my 98 VC so I can send it out for powder coating- got sidetracked by trying to get the KA head to the machine shop before I left.sigpic
92 240SX: KA/T25, nerd mobile
Fixed the vacuum line coming off of the intake and replaced the line from the booster to the check valve since it was partially collapsed... Did this all with a flashlight since we lost power a little while after I woke up tonight, hahasigpic
