1990 Protege 4WD
1 3 5
2 4 R
Found out I get to change another ball joint. Does everybody wear out ball joints every year or two, or is it just me?1990 Protege 4WD
1 3 5
2 4 R
Nope. I think one of mine is still original actually, maybe both. 270K miles
Maybe its the climate difference since we have little to no rain here and everything is dry.92 Mazda MX3 GS> For sale, $1750 OBO
Aluminum CAS/Distributor caps
BP oil jet eliminators
EV14 fuel rail spacers
More stuff coming soon.......
I've been using Moog for the last few years. Maybe it's what I drive on or how I drive on it. It's been a common wear item for me on all my BGs.1990 Protege 4WD
1 3 5
2 4 R
Originally posted by me109 View PostIs it automatic?Beater=/= Sleeper
Originally posted by me109 View PostI've been using Moog for the last few years. Maybe it's what I drive on or how I drive on it. It's been a common wear item for me on all my BGs.Beater=/= Sleeper
1 3 5
2 4 R
My ball joint is not the problem this time. I put the new one in and it wobbled as much as the old one did. The knuckle is worn away. I will try slotting the pinch-bolt holes and maybe cutting more material away from the slot in the side, then grind the bore smooth and squeeze it down harder. I hope that works.
The frustrating part is that I have a spare set of front knuckles, but when I went to get them I only found the right side, and of course I need the left. Also, my front left caliper is fully extended and leaking. The inner pad is down to the back plate while the outer one has about 1/4" material remaining. So I figure I might as well get my spare front calipers out so I can swap them out, but they're missing too. I found my rear set and some brackets for the front, but that just isn't helpful right now.
So much for order. I put a lot of effort into organizing and tracking my parts so I can find what I need when I need it. Today I am more than a little upset that it was all for nothing.
Comments/suggestions are always welcome.1990 Protege 4WD
1 3 5
2 4 R
Originally posted by me109 View PostMy ball joint is not the problem this time. I put the new one in and it wobbled as much as the old one did. The knuckle is worn away. I will try slotting the pinch-bolt holes and maybe cutting more material away from the slot in the side, then grind the bore smooth and squeeze it down harder. I hope that works.
Sent from my SAMSUNG-SGH-I747 using TapatalkMike
2000 ZX2 S/R-My DD
2002 Focus-DD (For Sale)
1998 ZX2- Girlfriends DD
1999 Escort Wagon- Project(rusty)
1997 Escort Wagon- Scrapped
