Replaced the alternator on the Protege tonight. Man, what a bitch that was. 2.5 hours to remove, .25 hours to install the new one. lol
did you grease the slide in the alternator base?(the part that squeezes against the block) & the bolts???
if not you might think twice about doing that---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Something started howling at me on the drive to work this morning. Pretty sure it's the front diff.1990 Protege 4WD
1 3 5
2 4 R
Pulled the GTR ecu out. its up for sale in the FS section.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Originally posted by FE3-323 View Postdid you grease the slide in the alternator base?(the part that squeezes against the block) & the bolts???
if not you might think twice about doing thatTeam Fail Motorsports
That's just the nature of the beach.
Originally posted by ThatGreenBG View PostI didn't. You mean the long bolt on the bottom? Why? To stop them seizing up or something?
I couldn't get the bolt out of the alt for my P5 regardless of how i tried....---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Originally posted by FE3-323 View Postyes it helps it to keep from seizing. steel+AL=self weld too so always always grease bolts that go into aluminum.
I couldn't get the bolt out of the alt for my P5 regardless of how i tried....Team Fail Motorsports
Originally posted by ThatGreenBG View PostPictures really do it a lot of justice.
It's been hit at both ends, the rear incident by a tow truck at about 30mph while I owned it, and the front, which left the nose skewed and was never repaired properly by the previous owner. There wasn't a straight panel on it and the spare wheel well was Swiss cheese. The doors leaked water like screen doors and the windscreen trims were replaced with some rubber stripping which was caulked in by the previous owner. The engine smoked and burned a quart of oil every thousand miles, and so on. It was far from a nice car. My Protege is a far better car that has never been wrecked and has a well-documented service record.
I loved it, and feel bad for junking a BG 323 tub, but it was never going to be what I wanted it to be, let alone a decent car in general. It was a paperweight taking up space in my garage and I had to make the call.
eh i guess its too late now---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Originally posted by FE3-323 View PostWhy didn't you post up a part out. I woulda asked for parts from it.
Plus, I called the first "Junk Cars" number on Craigslist, expecting to just get a quote, but the guy happened to be around the corner from my house and offered me $400 cash on the spot. I couldn't say no.Last edited by ThatGreenBG; 08-14-2014, 07:46 PM.Team Fail Motorsports
the rear lights looked* in good shape---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Originally posted by FE3-323 View Postthe rear lights looked* in good shape
I had planned to pull some bits and pieces off, but like I said above, the junk guy was around the corner with 400 effortless dollars.Team Fail Motorsports
