changed the oil (it was down like 1.25 quarts after 3500 miles, ugh) and ziptied the rear bumper back together
nice snow!! i like the way it has nifty holes in it & that portion of color
( i feel your pain)---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
was it left uncovered??---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
one of my full-boost mis-shift adventures blew the cover off the top of it, I never bothered replacing it.
also never expected my engine bay to turn into a snowbank, sooooooo
I mean, if this happened last year too, I'm not going to worry about it, since it started and ran perfectly a few months ago after sitting for over a yearsigpic
92 240SX: KA/T25, nerd mobile
pull it off & dry it out. spray it down with something that will force the water away but isn't flammable/corrosive to electronics.
worst case scenario you have to pull it apart & clean it up/ re-RTV the bottom back on---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
64 degrees, unbelievable, so I cleaned out the back seat and the trunk, both having turned in to a storage bay. Much cleaning and recycling later the car is a car again and not a storage unit.
Now what to do with my extra rear strut bar...
By the way Atomic, looking good. I should be having that type of weather out here. Odd year.1990 Mazda Protege LX, owned since new
That's a beautiful picture Atomic, belongs in an art gallery!
I finally got the car back on the road, been driving it and when I got to work, I put the key in the trunk to get my work grip and boots, and the key snapped.
Got a ride home thinking I was going to have to swap out the lock set there at work, but found a spare I didn't know I had.
So project for today is put my NOS lock/key set in with the new ignition lock cylinder and ignition switch.Mazda
1988 Black 323 GT
DOHC 16 VALVE TURBO
why not just remove the trunk cylinder & have the key taken out at a shop???? that'll be a hell of alot less hassle.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
I broke a nut breaker on my exhaust today. I honestly have no idea how I'm going to separate it. I don't think I will. When I get back to the mainland I'll probably just mod the 4-2-1 pacesetter to not suck(give it a flex pipe and mill the flange).
Fixed an issue with my control arm bushings, look for my gripe in my previous thread.
I also fixed a water leak, although I think my radiator may be leaking from the end caps at present, but that's only at "16+psi" according to the pressure tester I was using.
And I riveted my under panel tray that had been held together by zip ties.
Beater=/= Sleeper
yo nerds, probably moving to somewhere I can't do much work on the car in the fall (no garage, no air tools)
what kinda **** do I need to do to this ****er so I don't have to work on it ever?
already on the list:
-timing belt/idler/tensioner
-tie rods (just outer for now, maybe inners too)
-rebuild K-Sports
-possibly replace transmission/clutch/flywheel (diff makes spaceship noises)
-figure out where the coolant is going
I'm sure I can do brakes and oil changes and **** like that there, what am I missing?sigpic
Wheel bearings
half shaft bearing
replace the axles while they're out
Go ahead and do the inner tie rods ****s not hard
Steering rack bushings
front sway bar bushings
ball joints
front/rear engine mount depending on age/looks
Do the oil cooler water lines if they're over 5 year old.Beater=/= Sleeper
You could man up and work outside with hand tools.1990 Protege 4WD
1 3 5
2 4 R
