In attempting to make sure the LC1's analog output is properly configured for narrow-band simulation I've discovered I no longer own a laptop with a serial port.
I'm glad I noticed this before installing it.I guess I can drag my PC outside if push comes to shove.Beater=/= Sleeper
I'd prefer to not use an USB intermediary if at all possible. I suppose my old world stance on com to USB controller latency/throughput is unfounded though.
As long as I'm not data-logging **** wouldn't matter either way.Beater=/= Sleeper
With the bus speeds of newer computers, there shouldn't be an issue with that. I specifically use an IOgear usb/serial adapter for working with routers/switches/UPSes, and I've also used it to interface with the diypnp MS setup in my buddy's '82 Camaro with dual gen5 m90's.
worklog
323: fixed the exaust last fall, drove it a few times, heater core's plugged again, too cold to drive in winter, parked mostly. drove it across town last week.
95 Wagon: still parked with a bunch of parts in the back, and the engine in the garage.
90 4WD (blue): still parked in the garage, I need to finish the windshield bodywork, put the stupid thing back on the ground, and drive it.
90 4WD (gray): still on jackstands in the garage with the Mazdaspeed LSD in the rear and the engine/harness yanked and ready to re-wire. Might end up doing the GT-Four drivetrain swap since the rear crossmembers are nearing completion, and I seem to be doing anything at a snail's pace these days.
92 MX3 GS: sold off some parts for a racecar build (Racerboy). just waiting my extraction of the steering and some suspension to put on the 323. Saw some guys at LSPR last year running an MX3, I was going to see if they wanted the shell, but I never got their contact info.
85 744tic: in storage. needs air in the tires, and fuel line replaced. kinda unsafe to even start up with the amount of fuel hemmorhaging out.
98 OBS: 245K, still running strong, no leaks except for a tiny exhaust leak due to salty road conditions. Might have to swap in a 2.5 at the same time as a fresh exhaust. but I hate to take out a perfectly running and reliable engine.
04 SV650s: drove it to work, but I tweaked my back so riding hurts after awhile. Washed it before the Slimey Crud Run this spring.
01 GS450L: moved a carb from a box to my desk in the house. I'll eventually disassemble, clean, and put in new o-rings.
78 Murray 20" bmx: aired up the tires, did some brake skids.
in other words, I've been one lazy guy for the last several years!!!
--sarge
If you start a lazy guy club, I'll join it.1990 Protege 4WD
1 3 5
2 4 R
In my last experience with com/serial to USB it was more a problem of packet loss than bus speeds. I'm sure a bulk of the issues was me setting up something wrong at the time. But I never had any problem previous when I'd used it with my every I/O on the planet thinkpad.Beater=/= Sleeper
put a new battery into the 323.
raised it 25mm in front 10mm in the back. (its definitely P.R. status right now) I don't think it'll scrape with a full trailer load now tho. and 16" wheels fit in the front without scraping too.
used it to pull out an evergreen bush, then used it to trailer all of the bunk from removing it to the local yard waste site.
felt pretty damn nice to drive it again. altho it needs a certain cleaning....---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Today we replaced our valve cover gasket, intake hose, spark plugs, air filter, dome light bulb, door switch, got our a/c running, and hit 53k miles.
The shop told me they couldn't test the a/c for leaks because the a/c clutch relay was bad and wouldn't turn the compressor on. They said they couldn't get the relay until Monday. They lied. I got home and tested the relay, filled it with freon, and it's holding pressure and blowing ice cold. They charged me $50 for a diagnostic fee.
And I'm assuming this is what spark plugs from 1993 look like.ClubProtege
