parked till spring.... winter has come
I didn't get out to the garage to put things back together to take it all out... it didn't get past 37°F today.. so, nope....1992 Ultra Blue Metallic EGT - The 'scort with no name - crap>reliable daily>rallycross prep>stage rally
insert many sad faces now---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
I installed my studded snow tires on the wagon the other dayEscort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
Originally posted by atomicEGT View Postwhat is this "winter" you speak of? haha
bolted the trans back to the motor.. attempted putting the passenger side motor mount on to secure it, but that was being difficult. figured it's not necessary to have it while bolting getting ready for the rest to come out.
Drained trans fluid
Noticed i don't have a socket large enough for the hub nut.
Tried to unbolt the tie rods from the spindle so i can swing it out of the way with the axle attached.
Regardless of how it looks on paper, it's still progress. slow, slow progress1992 Ultra Blue Metallic EGT - The 'scort with no name - crap>reliable daily>rallycross prep>stage rally
Originally posted by azgtx View PostCareful there...hurricane season still has another week to go. Florida has been lucky the past some odd years. We have a home in Mobile ( not the same as Miami though) as well that saw some of Katrina right after it was built..lucked out there. You will get cold there but nothing that you are used to that you can't handle in your bermuda shorts and flip flops.sigpic
92 240SX: KA/T25, nerd mobile
Trouble shot BG horn not working. Determined it was the clock spring pretty easy, Thought it was just dirty contacts at first. But it was a dry joint.
After re-flowing it up I broke it trying to get it back in.
Had to solder all 3 of them after that.
Potted/Jbwelded the **** out of it after that. No vibration or ham handedness will break this guy.
Clockspring benches fine, so unless I botched something in the reinstall everything should work fine.
I think this should also fix the Cruise control issue I had where I would have to really wail on the buttons from time to time.Beater=/= Sleeper
Clock spring worked great.
In looking for a gasket for the manifold air valves I found out there are different part numbers for the valves themselves between ATX and MTX
BP0513190A MTX
BP0613190A ATX
Really SUBTLE difference in the part numbers.
I think this might be a good solution for people that have a bad cold idle with a turbo setup(like I did previously), and wouldn't be surprised if the ATX on doesn't come on the turbo'd cars factory.
And for reference the gasket part number are
Intake mani air valve rubber gasket B6S713ZC7
Throttle body IAC rubber gasket B55113W89Beater=/= Sleeper
the inner support structure of my hood apparently has told me to go **** myself, since it's no longer bonded to the skin very well and is starting to wear a groove into the Iceman.
used some two-part epoxy to glue the hood/my fingers together, and wrapped the intake pipe with some of that silver thermal tape while I was at it.
also got my Trust magnetic oil drain plug in the mail todaysigpic
put some heat barrier on the inside of the garage door to try and keep the car warm (and me while in their). pretty lame. i'm feeling like it may have been a waste of money.. oh well...
http://www.amazon.com/gp/product/B00...ilpage_o06_s001992 Ultra Blue Metallic EGT - The 'scort with no name - crap>reliable daily>rallycross prep>stage rally
doesn't look like there is any insulation to that crap ^^ they make foil backed r3 & r6 in my region that is commonly used for wrapping duct piping. but works great to insulate garage doors---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
No difference than a damn heat reflector on the windscreen of a car on a sunny day.. Found this over at HomeDepot. Will consider it once payday comes around again..
http://www.homedepot.com/p/Unbranded...-pcs/203630159
Expecting to get above freezing in the next week, so that's good. Need warmer conditions for using adhesive1992 Ultra Blue Metallic EGT - The 'scort with no name - crap>reliable daily>rallycross prep>stage rally
