    technically..... both
      Bought a new header today.
      FS Forged H beam rods
      awaiting test fit
      Aluminum CAS/Distributor caps
      BP oil jet eliminators
      EV14 fuel rail spacers
      More stuff coming soon.......
        Ordered a set of Whiteline lateral link bushings from Corksport today. Tired of these universal bushings walking apart.
        SPI swapped
        http://www.cardomain.com/id/WhiteLightning96
          FYI, I ordered the same set. They are, as I suspected, for the mx3/pro4wd ttls.
          1988 BF GTX
          1990 x2 BG AWD Protege
          1991 Escort GT- SOLD
          2005 Corolla
            So that means they will not work?
            SPI swapped
              From whitelines web site I could not find a listing for ttls bushings for an Eunos Mx-3, but they listed the 2wd and 4wd bg chassis as using the same ttls bushings.
              SPI swapped
                It is my understanding that the BG 2wd ttl's use a bushing that has a 32mm od where it sits in the ttl. The MX3 and Pro4wd use a 36mm od bushing. The whiteline kit that corksport is selling is listed as 36mm on the white line website. I am going out to the garge right now to verify this myself with my calipers. I post the pics shortly.
                1988 BF GTX
                2005 Corolla
                  Got some new Balonies. Mickey Thompson ET Street Radial II's in 205/50/15 :-) Can't wait to try them out. My CV shafts are toast and possibly my wheel bearings. I have new replacements waiting to go on, but no time :-( The CV shafts were one of the good used parts on the car, as they made no funny noises on the MX-3 parts car. They make all kinds of horrible noises now after a few months of blissful torture LOL.
                  It felt noticably slower with the 225/50/15 BFG drag radials Vs the 205/50/15 Falken's Azenis RT615's, so hopefully the Mickeys will do the trick.
                  BFG's in pic. I am going to put the 225's on the Muscletang. (The car they were intended for originally)
                    Hey look I found another BG!
                    -Steve
                    94' Protege < Worklog<SOLD!
                    VF10 powered!
                    262 Whp & 257 Wtq
                    13.1@107
                    '02 Suzuki Bandit 600s
                      Blew two more AD FAN fuses, changed condensor fans, blew another fuse. Put my original AC switch back in. Haven't retested yet.
                      1990 Protege 4WD
                      1 3 5
                      2 4 R
                        Picked up a forged short block and another g series transmission with axles for it. New plan is 400whp. This motor is more than likely getting the billet oil pump gears. I would like to use an na head but I doubt my stock bp head that lost oil pressure would be a good candidate. So it looks like my gtx head is going on.
                        bp swapped escort lx, gtr ecu, gtr intake manifold, A code VAF, rx7 460cc injectors, ky clutch, holset hy35 turbo on 8lbs, 38mm tial wastegate, ramhorn manifold, full 3 inch ss exhaust, walbro 255 fuel pump
                          [ATTACH]55904[/ATTACH]
                          That yours ace
                            Swapped out the leaking oil cooler house on the back of the engine. Not fun when you do it inside the car. Also tightened up my axle nut. Going to fill it up with water again tomorrow and see if anything else is leaking. Then it's time to start it and get it back on the road again.
                              Originally posted by M323GTR View Post
                              That yours ace
                              the sedan is, the hatch is Josh Chaney's.
                              -Steve
                              VF10 powered!
                              262 Whp & 257 Wtq
                              13.1@107
                                Still blowing fuses.
                                I changed the relay for another one I had around. It didn't fix the problem. I realized it must be the clutch or the wiring between it and the relay. Nothing else could blow the AD FAN fuse since I already changed the fan.
                                1990 Protege 4WD
                                1 3 5
                                2 4 R
