heh, got a parking ticket on my parts car. it came with no title, so its not in my name, and thus, not my ticket.
im still trying to track down the title for it tho.
loves BGs too much for his own good...
93 pro lx. daily runaround until a straight shell can be had.
73 datsun 260z, yet another project in need of more love.
"yeah im sure you as a redneck and then a dude walking around with a mohawk, wearing gang rags... you're sure to stir up some trouble..."
Today I cleaned my dirty ass airfilter and oiled it, then installed the rear caliper spring mod...I ended up using longer springs but still does the same job. Definitely notice a HUGE improvement in how my hand brake feels though...and it's also solved my "sometimes I like to stick" parking mechanism in the right caliper
you know if you get it titled, it then becomes your ticket, and any previous tickets that car has, bc it follows the vin.
I need to adjust mine. Is it the same for the DX? Write up?
I took mine totally apart de-seized everything then absolutely packed every single moving part with grease. I did it back in july and haven't had any problems since but it was a ton of work.
bah, you people just don't know how to work with drum brakes my BHA stopped like a damn champ after I did all the brakes (rear drum equipt!) and adjusted the hand brake.
drums are great fpr being cost effective, and semi capable at their job.
but discs are so much more effective, less work to maintain, and less parts to seize.
if you have rear drum, just upgrade. its 6 bolts, and a bleeding. not bad. just do it.
EDIT: rear disc also weighs less. weight reduction a gogo.
I found 2 cars with rear discs at the junkyard yesterday. I should just pull them and buy the rebuild kits for the calipers, it would be cheaper then buying rebuilt ones.
Then I would only need rotors, pads, and adapters to finish my rear miata discs
94 Escort wagon--BP swap coming, VF10 Turbo, COP, EVO ECU, 03 ZX2 front end conversion "Hold yourself accountable before you are held accountable"
F2 Forged H beam rods awaiting test fit FE3 Forged H beam rods coming soon
Aluminum CAS/Distributor caps
BP oil jet eliminators
EV14 fuel rail spacers
More stuff coming soon.......
My codriver and I removed the Haltech E6k and harness, and got at least started on installing the Adaptronic E450C into the rallycar. I plan on taking my sweet ass time wiring the new harness in.
If we manage to git r dun without letting the smoke out, it's gonna be one smart machine. Not only does it autotune fuel on the fly by sniffing the wbo2, it autotunes the ignition listening to the knock sensor.. not just "Oh I hear knock let's put a 10 degree hole in your curve", but "add a little advance till I hear something then back off a touch at that part of the map and keep adjusting elsewhere, but take it easy above where I heard knock"... and full individual injector control, batch on startup/full sequential otherwise, map tuning or volumetric efficiency tuning, closed loop air/fuel/boost/ etc, and who knows whatall else. I don't think I'll try to have it do traction and launch control, but I might go for flat shift, and I think I'll let it handle IC waterspray. Mmmmmmmm
In these past months I lowered my car on some kyb/Megan 2" lowering springs.got some shoes for it dr20/nitto neogens.new steering wheel.replace the sunroof with the glass moonroof.installed a Megan short shifter.changed the sway bar link bushings to polyurethanes.change front brakes, both axles,seals,and fluid.whohoo! Now looking for some long tube headers and I need to change my exhaust piping.oh, painting her this week!
