Realized in the last few days, I need a complete new turbo back exhaust (not including the downpipe) It keeps causing my 2 bolt flange that connects the DP to the exhaust to leak...I can turn left and it seals, turn right...it leaks....car warms up, it leaks LOL
Originally posted by atomicEGT View Post90% of the time I drive like an old person (seriously, I shift at like 2K) so power gains up top at the expense of throttle response are not really gonna cut it.
Bad opinions are bad.
Sent from my Galaxy Nexus using Tapatalk 2Mike
2000 ZX2 S/R-My DD
2002 Focus-DD (For Sale)
1998 ZX2- Girlfriends DD
1999 Escort Wagon- Project(rusty)
1997 Escort Wagon- Scrapped
Originally posted by Mikey27 View PostThis doesn't make any sense, optimizing the stock intake by replacing the upper resonator with a straight pipe, and removing the lower resonator and cutting the air box(and optionally adding a large reducer) is intended to IMPROVE throttle response. Beyond that fact, the physics behind the mod are true in theory. Think about it, remove a chamber (that dampens the air movement, thus slowing throttle response (slightly), and opening up the air box so it can have zero restriction (restriction that could slow throttle response (even though this could be negligible)) both will net better velocity though the intake, not harm it. There is a reason the mod is so popular, it works. The only throttle response killer is so called "cai's" that either are too large, or too long.
the best way I can describe it is like when you have the A/C on and you get that lazy response until the compressor kicks back off... which, obviously, would be something to check, except that it does it even with the climate control set to off.sigpic
Originally posted by Boosted Escort View Postpart of my spark plug broke off and landed inside the motor. Not really sure the best way to get it out. I can see it inside but so far my attempt to use a shop vac have failed.
All I can say is the only way it's coming out is compressed air and hope. If you can get the exhaust valve open, that would be best rather then blowing it into the intake.
2000 ZX2 S/R-My DD
Originally posted by atomicEGT View Postdude, all I know is that I drove it to and from work and drove a stock one at work and there is definitely a huge flat spot in the response compared to stock, and it wasn't like this before I did the mod. if you hammer on it the car rips, but I'm not driving WOT everywhere just to get it to move.
2000 ZX2 S/R-My DD
Originally posted by Mikey27 View PostThis is the second time I have heard of this in the last month. How the heck does one shatter a sparkplug, and inside the motor at that?
Originally posted by Mikey27 View PostI didn't mention it in my post, but it sounds like you have a leak in the intake. Did you use the correct size pipe? Is it larger on one side than the other? Is it thick wall pipe? Are you 100% sure it sealed up good? Did you perhaps miss putting the brake booster line back on if it was removed?
nope, not 100%. one of the things I'm going to check. all hoses are connected properly.
also, I'm wrong in blaming it entirely on the resonator removal- I'm looking into other **** (TPS, throttle cable, etc) because with my luck, it may have just been something that failed at the same time as I did the mod. as you said, pretty much everyone does it, so the odds that the problem are caused solely by doing this mod are kinda slim.
I'm mostly just frustrated, with the exception of the coils/wheels/lights every single thing I've tried to do to this car to make it a little more fun has actually made it worse.sigpic
Stick that m45 on it. Run an fmu and AFPR. Call it a day. That ought to solve any throttle response issues
Seriously. Do the math for pulley sizing, give it like 3-5 psi, add a tiny fun factor, reliability and longevity shouldn't be affected since you never really beat on it.
I know you don't want to work on it, but a few hours to fab it up and slap it on, a few more hours to work out bugs, then leave it alone and monitor AFRs for a while.Current:
68 Torino GT Fastback
86 MR2
91 F150
94 Escort Wagon BP swap
99 Escort Wagon BP swap
00 Miata LS
08 Arrow AX8
14 Mazda5
Originally posted by Boosted Escort View Postpart of my spark plug broke off and landed inside the motor. Not really sure the best way to get it out. I can see it inside but so far my attempt to use a shop vac have failed.Cincinnati, ohio Bengals for life
"Who Dey"
Originally posted by atomicEGT View PostJack- this is gonna sound dumb, but before you replace the exhaust, try putting worm clamps on all the rubber hanger things and see if that makes a difference.-Jack
Kinda in need of some quick cash to finish paying for this wedding. Anyone need/ want to buy anything that I have that wouldn't cease my car to run and drive properly?
Sent from my iPhone using TapatalkMy car is a Vazondissan. Part Nissan. Part Mazda. Part Ford. Part VW. Part Honda.
