BG w/ front end damage doesn't run
    So I'm lookin' at this LX on CL, It's had a front end fender bender that broke the rad fan, the guy hasn't overheated it. http://yakima.craigslist.org/cto/3050988091.html
    There is an overall engine bay pic on the CL ad, attatched is a closeup of the intake tube right after the VAF. The guy says it hasn't run since the crash (May 19) He thinks it's the kink in the intake tube. Will this be an easy fix or could it be something else, I thought it might be an inertia fuel switch that was tripped in the collsion, but I did some searching here and the Mazdas don't have them.
    Thanks in advance
    Kellen
    edit* I should mention that I only need a sound engine and tranny out of this to sap into my Festiva. Thanks
    If It was running when it was in an accident then the motor is fine. Assuming it hasn't been years and years of sitting. My guess would be a wiring or air flow meter issue and the kinked intake tube wouldn't help for sure.
    -Steve
    94' Protege < Worklog<SOLD!
    VF10 powered!
    262 Whp & 257 Wtq
    13.1@107
    '02 Suzuki Bandit 600s
      The bend in that hose *will* keep it from running.
        looks sound for a drivetrain option
        I agree lol, looks in pain.
          Well I got it, came with sweet speakers. 675$ delivered. Got the hose unkinked checked fluids to start it, no water, alright: so I dumped a waterbottle in and it all came out the bottom How bad would it hurt the car to just start it with no coolant to make sure it runs? and would it be at all possible to drive it 50ft up a hill? I don't want to tow/push it but I will if necessary. I thought it had 3/4 tank of gas too, nope, guage is stuck. And the tank is bone dry. all I had was 3/4 of a gallon and it wouldn't even cough or sputter on that. Hoping that's the only issue
            to start it just for a few seconds without any coolant wouldn't be an issue. Put some fresh fuel in there and see what happens
            -Steve
            VF10 powered!
            262 Whp & 257 Wtq
            13.1@107
              Yup, gonna get some gas today and see what happens, before I found it was drained it cranked well but wasn't even coughing or sputtering so gas is probably the only missing ingredient. BTW as a festiva owner and enthusiast, even the Protege's engine bay seems much more cluttered with all of those frivoulous options like Power steering and AC. Also doesn't help that everything's about 3 inches further back from it's factory installed location.
                Protege still don't run. It's got a couple gallons of gas in it now. I pulled off all of the intake tubing before the VAF. I can push the VAF flap when the key is "ON" and I can hear the fuel pump humming away. I can get the car to crank but no cough or sputter. The PO said they just had it towed home and hadn't run it. What would be the first thing anybody here would check? It's currently in a not very dissassemble friendly location and I leave tomorrow for Honduras I'd like to get it running before I leave but that may not happen.
                Now it's pouring down rain and I don't have a covered work area. It's got oil, doesn't hold water. I'm just a llittle puzzled on where to start.It also doesn't appear to be leaking anything besides water, I didn't see any gas leaks.
                If a Mod wants to move this to the engine/drivetrain section that would be appreciated!
                Thanks Heaps
                  Did you try a different distributor?
                    There is NO intake tubing "before the VAF" it is all after that. So if you took any tubing off, the VAF is not in circuit, and the car will not work.
                    With things (like the VAF) pushed back against the coil and ignitor and all the critical VAF and IGN wires, you should expect it to not run.
                    Maybe it has saved you from doing anything really stupid.
                    Have you looked at WHY the water is running out?
                    Is or was the engine itself pushed back, crushing fuel lines etc.?
                    Have you ever worked on a car before?
                    No offense meant, but:
                    You are certainly not competent to be swapping engines given these questions and that picture.
                    You can start it without water 10 seconds, NO driving up a hill especially!
                    FRM
                      There is a little tubing before the VAF. It runs down and around into the fender.
                      1990 Protege 4WD
                      1 3 5
                      2 4 R
                        @ gofanu I took off the small airbox with the filter that feeds into the VAF, I think you misunderstood me. I left the VAF and the tube between it and the throttle body intact, I just unkinked them by taking the battery out and giving the tube some space to exist without kinking (kinky isn't it ) The water is running out because the radiator is ruptured. Yes I have worked on a car before. the engine itself was not pushed back from what I can tell, I don't think any fuel lines are crushed. It looks like the PO rear-ended a truck because it looks like the bumper pushed in the grill/headlight area, but not lower and the hood is intact and not crumpled (sort of like pushing the middle out of a sandwich) I pretty much figured I wouldn't be able to drive it up the hill, I was just hoping I wouldn't have to push/tow it. And the picture was not taken by me, it wwas taken via iphone by the seller. I might be able to get a fresh pic of things tomorrow.
                        @Turpro I don't have a different dizzy to put on My friend is a computer/electronics guy and his dad works for Fluke. My friend will be helping me deal with the electrical side of things as far as why it ain't runnin'. Sadly, after I get back from my trip on the 12th
                        I know to check the basics like checking for fuel pressure at the rail, checking for spark. But I didn't have the time/space to do this today, and the torrential downpur forced me inside. I am mainly just asking what you guys would check first with something like this, or if there is a common problem that shows itself in such circumstances as these.
                        Thanks Heaps guys
                        *Edit, I was a slow typer and just read what me109 said. Yup that is what I'm talking about, it was part of what was kinking the intake tube after the VAF because it had been forced up and in.
                          Well I would start by looking for stored trouble codes.
                          1990 Protege 4WD
                          1 3 5
                          2 4 R
                            I'll see if I can get that tomorrow. The diagnostic port with the plug I have to ground is on the drivers side firewall according to some forum searching, correct? My repair manual to tell me where everything is is in the mail right now.
                              Yes. It says DIAGNOSIS on it and it's hard to miss. Jump TEN and GND and look up the codes.
                              1990 Protege 4WD
                              1 3 5
                              2 4 R
