You need to get a multimeter and verify signals to and from the dist, and ecu. This is the sort of sleuthing I effing HATE to do. Don't let yourself rule stuff out too easy. If you have another running car, that's the only way to truly verify components like coils and dizzys actually work. I've swapped out stuff like that with what I thought were known good replacements only to find out much later that neither item worked on another car either, causign much hairpulling and cuss words.
Help needed No spark!!!
Well unfortunately ive the only BP I know of in the country, ill try pull some codes off the gt ecu. I've ordered a new coil and igniter so ill try them1989 BP Motor, 9.8:1 OEM Pistons, BP22 Intake Cam, VJ20, GTX Intake Mani, FMIC, Alloy Radiator, HKS SSQV I, K&N oil and air filters, Innovate LC-1, 10W50 Mobil
Ok, so I put the GT ecu in and pulled some codes,I had the injector plug disconnected at the time.
09 Engine coolant sensor
34 IAC valve
41 Intake solenoid
So codes 09 and 41 are because of the injector harness being unplugged, but I don't know why it's giving me the IAC valve. I've read some similar threads on various forums and the IAC code popped up in a few of them but no solutions posted.
I pulled the engine loom and I'm currently inspecting every single wire, and all is looking good so far.1989 BP Motor, 9.8:1 OEM Pistons, BP22 Intake Cam, VJ20, GTX Intake Mani, FMIC, Alloy Radiator, HKS SSQV I, K&N oil and air filters, Innovate LC-1, 10W50 Mobil
The loom is ok an far as continuity and resistance goes, I also meggered every core and the insulation was not broken anywhere. I'm so pissed about this ****, did the recent turbo conversion cause it?? Or was it a horrible coincidence??
Could a short in the alternator or a short in the other loom cause a no spark condition??1989 BP Motor, 9.8:1 OEM Pistons, BP22 Intake Cam, VJ20, GTX Intake Mani, FMIC, Alloy Radiator, HKS SSQV I, K&N oil and air filters, Innovate LC-1, 10W50 Mobil
Right, loom checks out fine. As does all the components associated with the ignition system!
I've a question about the tachometer, I used my multimeter and went between the Yellow/Blue stripe(ignition pulse) and ground and I had continuity, is this right? It's hard to tell from the wiring diagram if this is the way it's supposed to be1989 BP Motor, 9.8:1 OEM Pistons, BP22 Intake Cam, VJ20, GTX Intake Mani, FMIC, Alloy Radiator, HKS SSQV I, K&N oil and air filters, Innovate LC-1, 10W50 Mobil
It's ALIVE!!!!!!!!!
The wire between the tach and the plug beside the ecu became shorted to ground killing the spark.
Time to go boosting!!!!!1989 BP Motor, 9.8:1 OEM Pistons, BP22 Intake Cam, VJ20, GTX Intake Mani, FMIC, Alloy Radiator, HKS SSQV I, K&N oil and air filters, Innovate LC-1, 10W50 Mobil
