greaseable bushings???? inform mr more about this
Lateral link bushings ??
I wouldn't say that... urethane has a hardness as well which can be made any way you want in the range. ES bushings are a set durometer but still are not that uncomfortable... your ride is more so in your strut/spring/tire combo than anything else.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Have you tried calling them?My ClubProtege.com Feedback Thread
MOSI Race Dynamics - Aftermarket Parts Sales & Services MOSI Race Dynamics Feedback Thread
Screw energy suspension... email SUPERPRO.... i think you'll have better results through them.
ES is in it solely for the money. unless you have 10,000 bushings made and a blank check... most likely your not getting anywhere---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Originally posted by bpt323Screw energy suspension... email SUPERPRO.... i think you'll have better results through them.
The only other thing I found out was that the hardness of the bushings should be Shore A 94. I might try to just pour some myself someday, but it's going to be hard dealing with the shrinkage and all...
--FerdiIf you can't differentiate between brake and break, you should go back to school
What car has same rear axle as protege?? (except 323/gtr/gtx/mx3)... ford laser???
If I can't buy poly busnhings, and mazda sell only whole LL, I think that maybe ford can sell normal rubber bushings.
Last step for me is to make custom LL, and use some universal poly bushings, as I said before.
