do these rotors look ok to you?
Mild glazing??
If they're not too worn down have them machined.Ryan The middle child is always ignored
they look halfway new??? are they? do they give horrible vibration at the pedal and wheel?---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
They look ok, how do they feel?_________________________________
'12 Focus SE hatch
'05 Saab 9-3 turbo (sold)
'90 Mazda 323 GT (sold)
'04 Mazda Tribute (sold)
'92 Mazda Protege LX (sold)
'91 Honda Prelude (totalled)
'91 Honda CRX SI (sold)
if you're going to bleed them, ****, just flush the old fluid out and dump new **** in. It'll cost you a bit more, but I'm guessing that its never been done since you bought the car and the previous owner probably didn't do the **** either.
Describe ****ty compared to normal..Ryan The middle child is always ignored
you got fluid in your master cylinder res??Does your pedal " pump up"?
If yes do then you're brakes are n need of a serious bleeding.Ryan The middle child is always ignored
Ok try this. Step 1: Start the car and press the pedal and hold it down. Does the pedal fade to the floor? If yes it is a bad master cylinder, if no go to next step. Step 2: what color is the brake fluid and is it translucent? If it is almost black flush the entire system. Step 3: If your vehicle is equiped with rear drums, clean the brake dust off with some water, and adjust the shoes till the fit snugly into the drums. Aslo look if the rear wheel cylinders are leaking break fluid. These are the only things that will cause a "funny" feeling brake pedal. Good luck.Too bad I have AWD and you don't!
some air in the lines can make the pedal feel mushy... and it's easier to bleed the brakes then it is to replace the m/c or brake fluid._________________________________
'12 Focus SE hatch
My brake fluid is rust colored. Is that normal?1992 Mazda Protege DX
Tropical Emerald Metallic - limited mods
Click Here to visit my CarDomain page
Originally posted by TheMANthat's what bleeding is!Ryan The middle child is always ignored
now now folks...---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
