this may sound stupid, but after I clean my brakes (rotors all the way around) what kind of lube should I put on the parts? pins, pistons, mounting bolts, . . .
-spank
According to Permatex, it's an environmentally-friendly, non-melting synthetic lubricant. It's formulated specifically for caliper pins, sleeves, bushings and pistons.
uhh no.... **** that ****.... that **** dries out after some time (year or two)..... and then your **** is seized again.... and you take the **** out and it's all dried crusty nasty ****
use silicone dielectric grease.... I recommend 3M silicone paste... it comes in a can and a brush attached to the lid... silicone grease is what was used from the factory and it works damn good... never dries and no crusty ****
I want to say some smartass comment about the massive amounts of profanity, but editing this quote would have taken out all its meaning.
I looked up your recommendation on the 3M website. I believe it's the product with the part no. 08946, available in an 8 oz screw top can. Good to know that you've found it to be the best choice for caliper lube-I'll keep that in mind when I'm ready for my first brake job.
Also, since it's a dielectric grease it can be used to coat spark plug and coil terminal boots (to prevent tearing on removal) and low voltage electrical contacts such as those for the headlights and relays to prevent corrosion and ease connector removal. However, DO NOT coat spark plug terminals or high tension wire connectors with this product since the spec sheet states that it is not to be used where the voltage level exceeds 500V.
All in all, a pretty versatile product to have around.
I would recommend putting it on every harness you take apart. Provides a better connection and helps prevent corrosion. You can buy the special spark plug dielectric stuff, for higher voltages. Although the only version of that I've seens is the little packets they rape you for.
And yes, I can attest to the brake deal, on my 323 the brakes were done by a shop last(found a reciept in car), proper lubrication was there, that bitch was soo ****ing seized. I ruined one of the guide pins and the caliper trying to take that god damned son of a ****ing bitch apart. (Kinda quoting TheMan)
I had to look this up to make sure no one was doing something stupid. Caliper lube and dielectric grease are very similar. For Motorcraft XG-3, they are one in the same.
wow,
looks like i threw a spark, . . .
thanks for all the advise, . .
one more question, . . the only stuff i can find are those little $0.99 packages, where do you guys buy this stuff from online? and also where the heck do i get new rear M springs?
-chris
ok, . . . I feel like a moron, this is the first year I did my brakes by myself, . . years previously I bought my pads from the dealer, (much more expensive) and they came with the M-springs and the, i do not know what you call them but the plates that the pads slide on, inbetween the caliper and brake pads, not the bacling plates, but anyway I figured out that i needed to purchase a hardware kit, which had all that stuff for about $7 a wheel.
away thanks for all your help
spank hard, . . . .
- spankboy
