I have used silicone lube on all the external pins and such, but I'm wondering what grease should be used for inside the caliper? When I took these calipers apart there was a gray lube around the adjustment screw, adjustment cam, and push rod, the screw that moves the piston.
I'm guessing it was disc caliper moly grease, but wanted to check here first.
Originally posted by goldstar
