I've checked many part numbers and I'm posting them here to make sure I'm getting the right parts for a front brake conversion:
front spindles: 1g pro = 2g, 3g escort
front caliper, caliper bracket, rotor: crappy (smaller) 1g pro = crappy 2g escort ; good (larger) 1g pro = 2g EGT and all 3g escort
In that case, I should get front calipers and caliper brackets from a 3g escort because theyre newer. I still have 13" steel nasty wheels, so I'll need 14 or larger. I'll buy the rotors new.
Now for the rear... is the swap to rear disks worthwhile for braking performance, and are mx3 rear disks better than pro rear disks and is that worthwhile and possible (without changing the rear subframe)?
Thanks.
Thanks.
