i got a 94' dx that i just bought like 2 hours ago well the ebrake dosent work has this happened to anyone else? what needs to be done to fix it?
e-brake wont work
If you have drum brakes the adjuster levers need to be removed and cleaned and freed up ,then coated with anti seize . If you have discs the same thing will need to be done , Your park brake cable might need to be replaced
2001 LX 2.0 Grace green metallic with gold graphics,
Motegi MR12 rims in gold
Falken Zeix 502's 205/40/17,
MDC Enterprises short throw shifter,Sparco shift knob,
Sparco pedal set,Vibrant axle back muffler , MDC Enterprises CAIwith K&N filtercone,Ractive strut bar,MP3 rear swaybar,Tien S-tech springs ,AWR engine mounts,AWR adjustable endlinks,AWR rear trailing arms,Konig rear wing colour matched ,Altezza tail lights edges colour matched to car.P5 front seats,
P5 front conversion with side skirts
If its a DX probobly drums, either way burnouts and crap like that will jack with your ebrake, my friend bought a car and the ebrake worked perfect when he got it, locked wheels and everything, and then like 6 Ebrake Burnouts later the crap wouldent even try to grip whatsoeverJoe H
2000 Chevy Impala
3400 3.4 Liter V6
Fun Times
Fenderwell Intake w/ K&N Cone,
U-Bend Delete, Resonator Delete,
Flowmaster 40, Hi-Flow Cat, Optima Redtop
my cables were rusted together and one of them snapped.
I replaced them from partsamerica.com. I dont recommend the raybestos cables as they are severely lacking in quality. The connectors are aluminum and dont fit as snug as they should on the caliper side and they dont even have boots.
They do work fine however.
Originally posted by 13b_demoni got a 94' dx that i just bought like 2 hours ago well the ebrake dosent work has this happened to anyone else? what needs to be done to fix it?
Originally posted by 13b_demonit goes up with no resistence
Didn't make a new thread so I'm bumping this one. I had the e-brake repaired some years ago and since then it worked fine...until today. Protege was sitting for two days in cold weather, today needed to go out. Warmed it up as usual but the interior wasn't fully warm yet. About 30 seconds after leaving I'm coming to a turn (no one else around) and I tug on the e-brake [not super hard] (everyone likes snow fun once in a while) and it worked for a split second then I suddenly hear a noise and the lever has zero resistance. Now it goes all the way up and down, no resistance. I was barley moving when I pulled it. Is it bad or something that can be easily fixed? Was the cause being the interior/(or rear brakes) was too cold and a cable snapped, or was it just pain old age? '94 with rear drums. The last time I used the e-brake I was parking on a steep street three weeks ago.
I'm going to be stressed if I have to take apart the center console, I have never taken a screwdriver to any panel of this car ever. It's one of the few first gens left still bolted up perfectly from the factory.~ Stephen ~
-1993 Ford Taurus LX (R.I.P.)
-1994 Mazda Protegé SE (Canadian market trim pkg)
-1990 Mazda 929 S
-1991 Mazda 323 LX (Sold)
-1992 Toyota Corolla LE (Davesfarm) <R.I.P. Sept. 2009>
-1990 Toyota Corolla SE (Davesfarm) (still alive in 2013!)
-1994 Buick Regal Custom (Davesfarm) <R.I.P. Sept. 2009>
-1983 Pontiac Parisienne (Sold)
Originally posted by Cool_Steve View PostDidn't make a new thread so I'm bumping this one. I had the e-brake repaired some years ago and since then it worked fine...until today. Protege was sitting for two days in cold weather, today needed to go out. Warmed it up as usual but the interior wasn't fully warm yet. About 30 seconds after leaving I'm coming to a turn (no one else around) and I tug on the e-brake [not super hard] (everyone likes snow fun once in a while) and it worked for a split second then I suddenly hear a noise and the lever has zero resistance. Now it goes all the way up and down, no resistance. I was barley moving when I pulled it. Is it bad or something that can be easily fixed? Was the cause being the interior/(or rear brakes) was too cold and a cable snapped, or was it just pain old age? '94 with rear drums. The last time I used the e-brake I was parking on a steep street three weeks ago.
I'm going to be stressed if I have to take apart the center console, I have never taken a screwdriver to any panel of this car ever. It's one of the few first gens left still bolted up perfectly from the factory.sigpic
________
'94 MX-3
|229,000 miles and DEAD|
SOFA
KING
SLOW
