Installing the S/R struts and H&R springs this weekend and I'm getting an allignment done too. I don't want the standard allignment, but rather one with less toe-in for better response and as much camber and caster I can get without getting camber plates. Does anyone have any suggestions as far as settings go? What works best with these cars?
Allignment Settings
Caster isn't really adjustable in a BG, and I wouldn't **** with that anyways.
I just threw my car on the rack yesterday, and this is what I had:
Front camber:
Specified range: -.8 - .7
Actual: -1.2
Rear camber:
-Specified range: -1.1 - .4
Actual: -1.6
A little more negative camber than specified because my car is lowered. The tires still wear perfectly.
I wouldn't mess with toe too much either, or you will start eating through tires.
Originally posted by bandman659Well, the problem is that my front tires are getting chewed up on the outside edge. If I remember, that means too much toe-in. I was thinking zero toe in the rear and about 1/32 or 1/16 toe-in in the front.
why do you want so much camber and caster? just wondering? it seems to me like you dont totally understand the effect of camber and caster on your car. yes the outside edge can be too much toe. it is also positive camber. it can also be just your driving.mods: engine: fm stroker lightened and knifedged crank, 11:1, custom crank scraper, fully p&p head and intake mani, bored throttle body, flowed and matched stock injectors, rx7 vaf, apexi safc, gude race cams, modded ecu 8200 fuel cutoff, blaster coil, clutchmasters stage 3 clutch, fidanza fly wheel and timeing gears, msp diff, custom shortram in a cold air box
Originally posted by JhoI wouldn't mess with toe. Just leave it at the manufacturer's spec or else you will go through tires.Create your own VB Gallery here.
Originally posted by JhoCaster isn't really adjustable in a BG, and I wouldn't **** with that anyways.
slight toe out in the rear assists you in being able to make the back end more responsive to coming around.
let the alignment shop set your toe for the front.
beyond that, i think this is what your searching for.
Altho its not reccomended to change the position of the plates as you'll add positive camber which isn't what your seeking.
without camber bolts or plates your better off with a standard front alignment & only slight toe out in the rear.
A good alignment shop will be able to set it for you. after you align your toe in the rear you'll wind up with some negative camber to start with. H&R springs give you the added bonus of a good amount of negative camber. can't say as much for other springs.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
courteousy of yours truely---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Originally posted by Clean 4WDUm Yes the caster is adjustable on the BG... That is why the upper strut top has Four studs vs Two studs on the earlier BF... You can look at the strut top and see the strut stud sticking threw is offset.. When rotated in the proper position caster and camber both can be changed... Just thought You should know... The adjustment is a fair amount...
But the strut mounts only belong in one position. Like you said, if you move the strut mount around, it makes a BIG difference, and can really mess your alignment up. And like Ryan said, if you do move the strut mount, it will make your camber positive.
Your caster shouldn't be messed with. If it is off for some reason, then you have a problem, like a bent component. A better way to adjust caster, without affecting camber, would be to make the 4 holes that your strut mount bolts to oblong, so that you can move the whole strut and strut mount assembly without changing camber.
slotting aas you said is the only real way to adjust your caster. Most people do not go to that extent.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Originally posted by bpt323I wouldn't nessicarily go so far as to say that JHO, caster also has good & bad effects when moving /altering the angle/°
i believe you meant 4° of camber. not caster.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Originally posted by bpt323i believe you meant 4° of camber. not caster.
Front L R
camber -1.0* -1.0*
caster 4.0* 4.0*
toe -1mm -1mm
Rear L R
camber -.75* -.75*
toe -1mm -1mm
This is my basic awd set up for any awd car that gives the car a good high speed stability and a nuetral feeling. The rear toe in helps the car turn in better but limits the oversteer. There are lot of ways to minuplate the camber caster on the front of the BG without moving the strut top.. But that is the proper way to adjust... I am toying with the Idea of making some tubular lower arms for the front that are adjustable at all three points..
