I was changing my spindles on the 323 due to bearing problems and decided to go with the bigger spindles from the Ford Escorts to fit the "Big" brakes. For those wondering what is the difference between the calipers, i compared them side by side. The piston housings are identical, the difference is the part indicated with the blue arrow.
Basically, if you don't want to swap your calipers but want the big brakes and have the big spindles, get the different half, untighten the two bolts (17 mm) attaching it to the piston housing (red arrows) and swap parts. Preferably, get new bolts even though I used the old ones hoping they are fine.
The ford spindles are available everywhere and are easier to find than pro/323 ones, especially here in canada.
