Hi guys,
Yesterday I had a close call with my 94 DX and I'm going to take it to a mechanic. But before doing anything, I need your advice because even after reading related topics about my problems I'm still confused.
Here is a little history first. About 10.000 Kms/ 8 Months ago my brakes were jumpy and brake pedal was pulsating up/down like mad, so I took her to the mechanic. Front rotors have changed (pads were fine)and rear drums sent for machinery. That solved the jumpy/pulsating brake problem but I noticed brake pedal started to travel way too much ( I could push it to the stop ) and it's softer compared to before. But I didn't mind that time, actually I liked it..
I'm pretty sure he did not bleed the brakes after that brake job.
Over the time I noticed my brakes are loosing their efficiency, especially in mornings for a first 10-20 meters damn car won't even slow down. but I couldn't test them properly because of damn Ontario winter. And yesterday, I had a chance to test them on dry HWY 401 . Oh boy, that truck became bigger and bigger on windshield while I was pushing the brake pedal to the floor to only get a moderate braking... I took it to a local mechanic today who said pads are ok and wanted to change almost all the freaking brake system, starting with master cylinder..
So here is my question. Where should I start? I don't want to change MC first because my car has only 105000 Km on it, I believe a MC lasts longer than that. Or should I tell to guy start with a bleed, if so should I look for a mechanic with vacuum or other bleeding equipment?
Well I desperately seeking for advice now, any reply is appreciated
One thing for sure, if you want to improve your driving skills and overall mpg, try driving with weak brakes, that makes you alerted and aticipated all the time![Smilie](https://www.clubprotege.com/forum/core/images/smilies/smile.gif)
All the best,
Bozhan
![banghead](https://www.clubprotege.com/forum/core/images/smilies/banghead.gif)
All the best,
Bozhan
