hello i'm new to this group and to mazdas in general. my '91 323 needs a new lateral link (mazda p/n BR7028620). i really need to get this as cheap as possible so i was looking for aftermarket. i found one at a place called "mazda part store." the brand is "dorman" and the sku is RB520-814. problem is, the pic of the dorman part doesn't look exactly like the part on my 323. i asked them could they verify the corresponding mazda p/n and they said they don't have that info. many many thanks for any help.
help with verifying a part?
rear lateral link i'm assuming? is it the front one (where the swaybar mounts) or is in the rear one (with the threaded center)?Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
Welcome to clubprotege.
This would be a perfect junkyard item. Good hunting.1990 Protege 4WD
1 3 5
2 4 R
i dont really have any way to look up the part numbers, thats why i asked
i have one lying around, but it doesnt have any bushings in it. if you wanted to take the time to upgrade to poly you could use mine, otherwise it would be kinda useless
^he could press out his old bushings & put them in your link---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
