i cant find it now, but i had a link to an aussie article on sema welding where they took an old EVO 3 and put the front left tire on a ramp and opened the door. the door was totally miss aligned and had to be lifted to close it.
afterwards the car was stripped and put on a rotisserie and seem welded, afterwards and before the cage install they repeated the door test and the door (though still slightly miss aligned due to the hindges) wasable to shut with minimum effort due the the lack of the unibody frame movedment
think of it this way: staple 2 pieces of paper together with a slight overlap and only use 3 staples, can you still twist and move the paper enough to cause a lip at the edge?
