I'd take that whole Volvo.
junkyard gems/oem upgrades
yea, I'm a sucker for an old Volvo too...-Jack
I still like the 120s my dad used to have. The wagon was my favorite.1990 Protege 4WD
1 3 5
2 4 R
93 mx-3 v6 90 amp with the pulley swapped and about 1/16 of an inch ( I believe) shaved off the spacer to line up with the other pulleys. I also clearanced what I believe was the motor mount engine bracket so I could get the belt over the pulley and adjust tension like a normal person. I still had to use a belt one size up which is half inch longer I think?!?'91 Grey 323 B6 5 Speed - CRUSHED
'93 Red/Green 323 B6 5 Speed - DD
'91 Jeep Cherokee 4.0L Auto 4x4 5" Lift - Rec. Rig
'76 Plymouth Scamp 225 Slant Six 3 Speed on Floor - Non Snow DD / Awaiting Turbo & T5
grab a B8 throttlebody & put it onto the B6 intake manifold. you can port match the b6 intake manifold for that or even the BP tb(altho its harder) you can upgrade to the 4wire tps then.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Originally posted by FE3-323 View Postgrab a B8 throttlebody & put it onto the B6 intake manifold. you can port match the b6 intake manifold for that or even the BP tb(altho its harder) you can upgrade to the 4wire tps then.
^same as that for a BP. smoother throttle input to the ecu & ~1-2 mpg increase---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Originally posted by FE3-323 View Post^same as that for a BP. smoother throttle input to the ecu & ~1-2 mpg increase
^ start a new thread for that---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
