ordered these, and wasn't sure if they're just supposed to sit on top of the stock rubber boots to help prevent excessive play in the joint.
Energy Susp Tie Rod End Boots...
Chris
94 protege lx - gone and will be missed
2008 Mazda3 - recently acquired
"Life is tough, but it's tougher when you're Stupid."
-John Wayne
http://www.cardomain.com/ride/2978373
Tags: None
i bought these as well, couldnt figure out wtf you're supposed to do with themEscort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
i put mine orver the boot, and 3 months later they tore"Discontent is the first necessity of progress."
Originally posted by smoke187 View Postum you have to buy the grease fitting tie rod ends"Discontent is the first necessity of progress."
If you looked into it a little more, the urethane boots replce torn rubber boots. If you get the Spicer replacement rod ends, they come with blue rubber versions of this same design. They slip in place, covering the exposed joints when installed. You just need to be sure that they don't fold up on themselves. I've used them on the rally cars in the past, to use good ends with bad rubber boots.
-Jon R.Last edited by jrally; 11-25-2007, 07:50 PM.
I removed the polyurethane boots from the energy suspensions package and put them on the outer tie rod ends, they did not come with them.
From how they look, they'd just go over them but if they're just gonna tear in a few weeks, maybe i'll just leave em off. I guess it won't really hurt them to have em on.Chris
-John Wayne
what I also did was get these ones off of zxtuner, so my next question would be:
if they fit on a 91-96 tracer/escort, should they fit on our vehicles too?Chris
-John Wayne
