The one crossmember that supports the lower engine mounts. There are bushings at the lower rad support and at the rear by the LCAs. SRD use to sell some poly ones, now discontinued.
I know www.suspension.com has a bunch of custom flange/4-bar bushings and custom body mount bushings.
If someone could measure a spare set of those crossmember bushings, it would be greatly appreciated as Canada is really rough on rubber!!! As i'm sure other members would be happy as well.
This could also work for the shifter rod bushings (not the stationary) but those 4 little bushings on our shift linkage. I know zxtuner sells a kit of 4 for $24!!!! SUPER EXPENSIVE!!!!
So if someone wants to measure the shiftlinkage bushings and inner shiftlinkage tubing would help out dearly too!
Thanks...
JACK!
Thanks...
JACK!
