no more tease...the real deal
I don't usually say this to men but "that's huge"1993 Protege LX-Midnight's shadow SOLD
thats pretty wicked---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Originally posted by bam View PostWow, really makes you realize the little friction surface of the pads with the original caliper.
Originally posted by Saturna View PostHis response could be:
"That's OK, I don't usually hear that from men"
Jay
actually my response would be "i've never heard that from a man, and would prefer to never hear it again from another man"
failure of the hub? (i understand the whole larger diameter = more force/leverage) but u care to expand on what is it that ur "afraid" of failing?
the bracket is out of solid 3/8" thk. 1020 cold rolled steel. and all hardware are automotive grade. it's not going anywhere.
i'm sure there are concerns, u could either a) bring up some concrete explanation or numbers to support your concerns, or b) ask me or follow this thread to check up on my field tests and actual daily application....otherwise i'd appreciate it if u didnt just scream out about being afraid of "failure" of my parts.
the hub on the rotor is significantly larger than the hub on the car behind it. however, that is not a personal concern of mine (though im sure it could be for some). reason being the rotor is sandwiched b/t the wheel and the hub. it doesnt not receive any "lateral/horizontal" (side to side) forces, and more specifically the "unsupported" areas do not receive any special forces. the only force it gets is the normal rotational "torque" and that has nothing to do with whether the hub is supporting it as the support isnt even in the same axis as the rotation force. if u feel that the hub on the rotor of this set up would fail, then u should worry about any hub on any rotor on any set up would fail as well.
brake rotors arent made out of cardboard....the material itself can substain what it's supposed to be put through. have u ever seen/heard of a brake rotor suffer shear failure? the rotor's friction surfaces on all rotors arent supported by the hub, do you worry about that part of the disc failing?Last edited by Rayman; 06-14-2009, 02:07 AM.
i hope im not sounding rude, b/c i understand the cause for concerns, but so far the concerns i see are non-issues. it's like questioning whether the end of the spokes on a larger wheel would be more likely to break. or the outer edges of a bigger throttle plate on a bored TB would be more susceptible to cracking.
i'll continue to drive the car daily, and i'll report any suspicious activity. trust me, i dont wanna crash as much as u
