SR's are junk from every perspective i can offer. you just don't listen do ya frog get GR2's
strut ?
what are sr's?
are they the Tokico black ones? thats what i ran b4
Originally posted by minnesotapjCost of your fancy German built sports car $35k
price of your fancy sun glasses to match your German built sports car $200 dollars
Getting beat by a second hand 20 year old Japanese 4 door... Priceless!The only bummer about the world ending is that you can't turn to the person next to you and say "WOW! Did you see THAT?!!"
ill probly go with the gr2's
just want opinions
remove the probably & just get em---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
well the ZX2 s/r front struts are shorter, so the KYB front struts may be shorter as well, which would be more optimal compared to a longer strut, that way it has more clearance in the shock housing before it bottoms out.
Protege is different due to the top diameter of the strut rod, the 97+ ZX2 and SE are thicker, and use a different bearing (larger ID).
Hope this helps-Jack
^ i thought the same thing until i replaced mine and it was the same ID
