So I had to change my rear pads, no big deal there... WRONG! First the driver's rear adjuster set screw stripped the splines out trying to retract the piston. It did move some so I just went to the other side... That one worked perfectly and pad change was a breeze. Set the adjuster in till the rotor dragged, then backed off 1/3 a turn like the manual said. I got back to the other side and swapped out the adjuster hex insert thing. Same deal but it moved enough to get the piston close. So I said screw it, popped off the pad anti-rattle shim things and it was still a touch to tight. I had some sand paper and I took 0.020" off both pads. Fit nice and snug, but didn't lock the wheel it barely dragged. Then I tightened everything up, including the set plugs in the back of the caliper.
I go to test drive it and the pedal goes halfway until I get any sort of braking and the E-brake doesn't do diddly squat. I pumped up the pedal and it stiffened up. It feels exactly like the lines need to be bled. Before the brakes were always pretty good... Anyone ever run into this? I'm not leaking fluid anywhere either. I am trying to make it through the end of August before I get anything different (more than likely new) but man things are making me re-think that. I am 100% positive the bleeder is going to break off on at least one side when I go to bleed them... Always does.
Just tried pumping up the pedal till it was stiff and then pulled the e-brake. The brake had tension then.
